So, there are two ways to set device value - SetDeviceValueByRef and CAPIControlHandler. First I thought that SetDeviceValueByRef is just a convinience wrapper for CAPIControlHandler. But.
SetDeviceValueByRef doen't seem to work with physical devices like Raspberry IO outputs. It looks like it changes the value in HS ui, but output doesn't change.
So. I try CAPIControlHandler - it does work with Raspberry IO outputs - but is not reflected in HS ui.
So WTH should I be using? I use both and it seems to work - but it's ridiculous.
