Dirk,
I'm still at this. I had a lengthy exchange with Rich to get clarification on SupportsMultipleInstancesSingleEXE. i will try to summarize our convo later for others
I had to do a lot of refactoring on my code to make this little miracle occur.
I just wanted to check a few assumptions based on SupportsMultipleInstancesSingleEXE returns True
1. Main only gets called once when the plugin initially loads? that is, it doesn't get called again when a second instance is started
2. all the objects related to an instance must be contained in the HSPI class? So there is no data bleeding or corruption between instances
