It appears that some plugins are not setting up devices properly. Build 3.0.0.505 and later of HS3 will now perform a check on startup and check to make sure all devices are configured properly and log a warning on any errors. Parent (root) devices that have children need to reference all children in the AssociatedDevices property. Each child needs to include a single associated device which is the parent (root) device. In a future build of HS3 we will be enforcing this relationship and will be"fixing" the relationship if its incorrect. Please make sure your devices are configured properly. You can run build 505 or later and see if there are any errors.
See the HS3 Plug-in Developer Doc on Working with HomeSeer Mobile: https://help.homeseer.com/help/HS3SD...omeseer_mobile
