Is there any interest in a plugin for Bond Ceiling Fan controller if I write one?
  • #31
    Do we have a Bond plug-in?
    • #32
      Not yet. I'm about to start back on it. I was holding off waiting for the API to mature, but there is now a work around if it's not there yet.
      Frank
      • #33
        I'm also interested in the Bond Plugin. Any status change?
        Also, is there anyone on this thread that plans to use the Bond + HS Plugin in conjunction with the HS-FC200+? If so, how do you envision wiring the switch and fan? Or do you plan to bypass and leave the fan hardwired / always hot?
        • #34
          I also would want this Frank. I have been using a Bond controlling 6 fans and has worked flawlessly since I installed it. Be happy to test it for you.
          Bob Silver
          • #35
            Very interested in this. Using with IFTTT right now, but it's slow and not reliable. Trying to turn on a fan light with HSWD100+
            • #36
              Any updates? Looking forward to Beta testing, if needed. Bought the Bond a few weeks ago and it's been great!
              • #37
                Bond has been really slow getting out the API so could be a little while. Glad to see another Homeseer user close by!
                HS3 3.0.0.548 &HSTouch Designer 3.0.71 with 887 Devices, 515 Events
                Plugin's:
                BLBackup, BLOccupied, BLShutdown, EasyTrigger, Ecobee,
                • #38
                  I am in process of installing 3 fans that all need to be on the same circuit, and the fans do not allow for separate wiring of light and fan. Long story short, in order to automate them and be able to individually turn light/fan on for 3 different fans, i'm going to need something like this. From the looks of it, this integration probably isn't going anywhere anytime soon? Does anyone have alternatives (since I don't have a bond yet), that would work now with homeseer?
                  Thanks!
                  • #39
                    Thanks!
                    Have you bought the fans already?
                    Are they AC fans controlled by knob on the wall, or DC fans controlled by a remote?
                    I've been using DC fans (Lucci brand) controlled by the RFXCOM plugin and it works brilliantly. The same plugin/TRX device also controls my motorised blinds.
                    Just brainstorming: If you're locked to an AC fan, maybe a HS-FC200 on the wall to control all three fans in tandem, then see if you can wire something like a Qubino 1-relay module into the base of each fan to do the light?
                    • #40
                      Yes, I am interested. I have a bond device at home that controls 5 fans. Jose
                      • #41
                        I just added a Bond plug in for three fans and would be very interested in a Homeseer plug in. I also added a blaze automation B.One hub to control my split air conditioning system and would like to have a plug in for that also.
                        • #42
                          This is Version 1 of 2. This device works well without Alexa, Version 2 works with Alexa, and will allow you to set the speed via %.
                          Create a virtual device that will control the ceiling fan
                          Device Screen 1
                          Create an event that will monitor this virtual device for any changes.
                          The parameters are a comma separated string.
                          xxxx,bond-device-id,bond-token,name used in log
                          Here is a script that works with Bond Bridge v2
                          PHP Code:
                          Imports System.IO
                          Imports System
                          .Net
                          Imports System
                          .Text
                          Sub Main
                          (parm as object)
                          'parms() =
                          0Vurtual device ID to monitor;
                          '1: Bond device ID curl -H "BOND-Token: bond-TOKEN" -i http://bond-IP/v2/devices
                          2Bond token curl -i http://bond-IP/v2/token
                          '3: Homeseer Device Name used in log
                          bond JSON from http://docs-local.appbond.com/#section/Getting-Started/Getting-the-Bond-Token
                          Dim parms()
                          Dim dVal
                          const server "bond-IP"
                          If parm Is Nothing Then
                          hs
                          .WriteLog("Alexa Fan""Error; no parameters given " parm.ToString)
                          Exit
                          Sub
                          Else
                          parms Split(parm.ToString,",")
                          End If
                          dVal hs.DeviceValue(parms(0))
                          hs.WriteLog("Alexa Bond"parms(3)& ": " hs.DeviceVSP_GetStatus(parms(0), hs.devicevalue(parms(0)), 1))
                          Dim json_data As String "{""argument"":1}"
                          Dim uri As String "http://" server "/v2/devices/" parms(1) & "/actions/TurnOn"
                          Select Case dVal
                          Case 100 'off
                          json_data = "{""power"":1}"
                          uri = "http://" & server & "/v2/devices/" & parms(1) & "/actions/TurnOff"
                          Case 101 '
                          on
                          json_data
                          "{""power"":1}"
                          uri "http://" server "/v2/devices/" parms(1) & "/actions/TurnOn"
                          Case Else
                          json_data Replace(json_data,"1",dVal)
                          uri "http://" server "/v2/devices/" parms(1) & "/actions/SetSpeed"
                          End Select
                          Dim request
                          As Net.HttpWebRequest Net.HttpWebRequest.Create(uri)
                          request.Method "PUT"
                          request.Headers.Add("BOND-Token"parms(2))
                          request.ContentType "application/json"
                          Dim json_bytes() As Byte System.Text.Encoding.ASCII.GetBytes(json_data)
                          request.ContentLength json_bytes.Length
                          Dim stream
                          As IO.Stream request.GetRequestStream
                          stream
                          .Write(json_bytes0json_bytes.Length)
                          Dim response As Net.HttpWebResponse request.GetResponse
                          Dim dataStream
                          As IO.Stream response.GetResponseStream()
                          Dim reader As New IO.StreamReader(dataStream' Open the stream using a StreamReader for easy access.
                          Dim responseFromServer As String = reader.ReadToEnd() '
                          Read the content.
                          'hs.WriteLog("Response", responseFromServer)
                          reader.Close()
                          dataStream.Close()
                          response.Close()
                          End Sub
                          • #43
                            This is version 2. The virtual device used will work with Alexa and allow you to control a light switch that powers the fan. The commands used to Alexa are "Alexa Master Ceiling Fan 20%" "Alexa Master Ceiling Fan On" "Alexa Master Ceiling Fan Off". If the power switch is off and you ask "Alexa Master Ceiling Fan 20%", it will turn on the switch, wait 5 seconds, and issue the speed command for 20% of 1-6. The On and Off commands only control the light switch.
                            Create an event that will monitor the virtual device for any changes.
                            xxxx,xxxx,bond-device-id,bond-token,name used in log
                            Replace the bond-IP and bond-TOKEN with IP address and Token of your bond device. Both Ver1 and Ver2 are saved with a VB extension, script.vb.
                            Both scripting for Ver1 and Ver2 were taken from examples found using google.
                            PHP Code:
                            Imports System.IO
                            Imports System
                            .Net
                            Imports System
                            .Text
                            Sub Main
                            (parm as object)
                            'parms() =
                            '1: Z-wave Device ID on/off switch;
                            2Bond device ID            curl -"BOND-Token: bond-TOKEN" -i http://bond-IP/v2/devices
                            '3: Bond token                 curl -i http://bond-IP/v2/token
                            4Homeseer Device Name used in log
                            'bond JSON from http://docs-local.appbond.com/#section/Getting-Started/Getting-the-Bond-Token
                            Dim parms()
                            Dim dVal
                            Dim dSwitch
                            const server = "bond-IP"
                               hs.WriteLog("Alexa Fan", "Error; no parameters given " & parm.ToString)
                               Exit Sub
                            Else
                               parms = Split(parm.ToString,",")
                            End If
                            dVal = hs.DeviceValue(parms(0))
                            If (dVal = 0) OR (dVal > 100) Then
                               If dVal = 255 Then
                                 hs.CAPIControlHandler(hs.CAPIGetSingleControl(parms(1), true, "On", false, true))
                                 hs.WriteLog("Alexa Fan", parms(4)& ": Switch On")
                               End If
                               If dVal = 0 Then
                                hs.CAPIControlHandler(hs.CAPIGetSingleControl(parms(1), true, "Off", false, true))
                                hs.WriteLog("Alexa Fan", parms(4)& ": Switch Off")
                               End If
                               Exit Sub
                            Else
                               dVal = Decimal.Round((((dVal - 0) * (6-1)) / (100-0)) + 1, 0, MidpointRounding.AwayFromZero)
                            If dVal 0 Then dVal 1
                               dSwitch
                            hs.DeviceValue(parms(1))
                               If
                            dSwitch 0 Then
                                hs
                            .CAPIControlHandler(hs.CAPIGetSingleControl(parms(1), true"On"falsetrue))
                            hs.WaitSecs(5)
                            End If
                            hs.WriteLog("Alexa Fan"parms(4)& ": Button " dVal)
                            End If
                            ' Create a request using a URL that can receive a post.
                                Dim uri As String = "http://" & server & "/v2/devices/" & parms(2) & "/actions/SetSpeed"
                                Dim request As Net.HttpWebRequest = Net.HttpWebRequest.Create(uri)
                                request.Method = "PUT"
                                request.Headers.Add("BOND-Token", parms(3))
                                request.ContentType = "application/json"
                                Dim json_bytes() As Byte = System.Text.Encoding.ASCII.GetBytes(json_data)
                                request.ContentLength = json_bytes.Length
                                Dim stream As IO.Stream = request.GetRequestStream
                                stream.Write(json_bytes, 0, json_bytes.Length)
                                Dim response As Net.HttpWebResponse = request.GetResponse
                                Dim dataStream As IO.Stream = response.GetResponseStream()
                                Dim reader As New IO.StreamReader(dataStream)          '
                            Dim responseFromServer As String reader.ReadToEnd()  ' Read the content.
                            hs.WriteLog("Response"responseFromServer)
                            reader.Close()
                            dataStream.Close()
                            response.Close()
                            End Sub
                            • #44
                              Spooner Thank you for taking the time to put this little script together. It worked great for me! Cheers!!
                              • #45
                                Hi sirmeili!
                                Any update on a plugin mate?
