Is there any interest in a plugin for Bond Ceiling Fan controller if I write one?
    #76
    Originally posted by alexbk66 View Post
    I installed your plug-in without difficulty from Beta section. My Bond Bridge reads "unauthorized" and no devices are created for my fan that is controlled by the bridge. On configuration page, RSSI has no value. HS3 Pro Edition 3.0.0.548 (Windows). Elliott
      #77
      Man, did you read my post #71?
        #78
        Version 3.0.0.1 (BETA) - implemented some actions - which don't require arguments (i.e. Open/Close)
        Note: if you tried 3.0.0.0 already - it's a good idea to delete HS Bond devices before starting 3.0.0.1
          #79
          Sorry. All is good now.
            #80
            Installed and controls are working for my fan.
              #81
              Controls which take an argument (i.e. IncreaseSpeed) will need to be added on users request - I can't predict which ones, there's million of different Bond devices.
              When HST create a new subforum for the plugin - I will start a topic for Feature Requests.
                #82
                Really appreciate you taking the time to create this plugin.
                Plugin's:
                  #83
                  Understood. Appreciate, too, your creating this plug-in. Elliott
                    #84
                    My pleasure. Unfortunately it's more complicated than it looked at the beginning (as it always is ) - because the control commands are device specific, not very generic.
                    And Bond API is very powerful - it's possible to do more stuff from the API than you can do via Bond mobile app or your original remote.
                      #85
                      Great that you are making progress alexbk66! To clarify - this beta plugin only works for those testing HS4? Beta will not work under HS3?
                        #86
                        I have implemented the plug-in on HS3Pro. I don't have access to HS4, yet. Elliott
                          #87
                          It's actually HS3, but should also work on HS4. I will port later to native HS4 when HS4 itself is ready.
                            #88
                            Thanks for the response.
                            I installed the beta plugin but I do not get a root device created as per post #71 (I uninstalled/reinstalled but same result). I did go to the config page and created one but I'm not sure how to proceed from there. Have also rebooted the Bond a few times and can confirm control from my phone.
                            Thoughts?
                              #89
                              It means that the discovery (mDNS/Zeroconf) doesn't work.
                              Anything in the logs?
                              Are you on Linux or Windows?
                              You should be able to add the Bridge manually in Config page - Using the "+" button, then entering the Bridge ID and IP. But I didn't test it yet.
                                #90
                                I installed 3.0.0.1 this morning. All went well but the plug-in failed to get an authorization token, even after a reboot. With this error.
                                Jan-21 7:24:55 AM AK Bond ERROR [7372]: Bond Bridge: [Bond Bridge] AJ11979 (192.168.2.27): Execute '/v2/sys/version': Status: 'Error' Error: 'Unable to connect to the remote server' response: '' code: '0/' 'ConnectFailure'
                                The problem was that the firmware in the hub needed an update. I was running v1.x.x, it updated to v2.10.8. The. The token worked and the devices were created for 3 fans.
                                I know this is an early beta, the following is just informational. I can turn the fan on or off, but cannot control the speed. I can turn the light in or off, but all three controls (Toggle, On, Off) all toggle the light state. I cannot control the dim level of the lights.
                                Speed control generates these errors:
                                Jan-21 8:05:25 AM AK Bond ERROR [7372]: Bond Bridge: [Bond Bridge] AJ11979 (192.168.2.27): Execute '/v2/devices/00000033/actions/DecreaseSpeed': Status: 'Error' Error: 'Index and length must refer to a location within the string. Parameter name: length' response: '{"_error_id":7,"_error_msg":"bad argument"} ' code: 'BadRequest/Bad Request' ''
                                Jan-21 8:05:00 AM AK Bond ERROR [7372]: Bond Bridge: [Bond Bridge] AJ11979 (192.168.2.27): Execute '/v2/devices/00000033/actions/IncreaseSpeed': Status: 'Error' Error: 'Index and length must refer to a location within the string. Parameter name: length' response: '{"_error_id":7,"_error_msg":"bad argument"} ' code: 'BadRequest/Bad Request' ''
                                No errors are logged with a “Start Dimmer” request.
                                Click image for larger version  Name:	DB469F4C-9CBD-42C4-BCC9-D3158784C05E.jpeg Views:	0 Size:	55.7 KB ID:	1355637
                                Randy Prade
                                Aurora, CO
                                Prades.net
