Thanks will check!
Is there any interest in a plugin for Bond Ceiling Fan controller if I write one?
Originally posted by Timmy_G View PostUsing the + button didnt work for me
Originally posted by Timmy_G View PostDoes issue with mDNS possibly relate to the plugin not creating a root devive upon install of the plugin (as per post #71)
mDNS is required before that to find the Bridge IP address.
If mDNS doesn't work - you should be able to enter the address manually (when I fix it).
But mDNS problem is quite difficult to diagnose - there are many factors affecting mDNS, i.e.
1. the router blocking mDNS traffic
2. your computer having multiple network cards, including VM virtual adapters. I usually try to disable the once I don't need (when I have mDNS issues)
3. sometimes rebooting the computer fixes the problem
But try the ServiceBrowser first
Originally posted by alexbk66 View Post
Ok. I guess so. Just only issue is - the status is basically a copy of the Bond app, not the physical device. But better than nothing.
-So, just thinking about this...
Option #2 would seem to work for control/action as worse case you would just resend an existing action. So say it's Off and you want it On, you would turn it On. If it was actually already On, no problem. Same for initially being On. Fan speeds might be: At speed 1 and you want it to be Speed 2, you set it to Speed 2 even if it was there already.
So worse case you just resend a command.
Triggering on status or even just checking on a status might? also be problematic (ie on or off, speed 1-6, blind open partially, etc) as you might end up reacting to a false status/position? So if you see the fan go Off and you want it On, you'd resend the On command. Same for if it was already. Typically the Bond controlled device would be controlled by other inputs (temp, time, etc), not the current status of the device.
Probably worse case would be a race condition where an event keeps trying to change a state caused by a delay in the Bond Bridge->PI?
I'm assuming the Bond Bridge keeps track of the current status no matter which control input (Siri, Echo, HS3, etc) is used? If not, that might be another issue.
Z
Originally posted by vasrc View PostTriggering on status or even just checking on a status might? also be problematic (ie on or off, speed 1-6, blind open partially, etc) as you might end up reacting to a false status/position? So if you see the fan go Off and you want it On, you'd resend the On command. Same for if it was already. Typically the Bond controlled device would be controlled by other inputs (temp, time, etc), not the current status of the device.
2. May be for some devices there's actually possibility to get feedback (i.e. new windows shutters report position) Hopefully Bond will handle this (may be not yet)
3. So as I understand Bond keeps track of the current state only if device is controlled by the Bond, not original remote.
4. In any case the best I can do - is display the state I get from Bond. And hope they are smart to get it right.
Originally posted by Timmy_G View PostUsing the + button didnt work for me.
Note 1: Sometimes config page mis-behaves when doing that (i.e. new device doesn't show, or fields are duplicated) - just refresh the page.
Note 2: Remember to reboot the Bridge when adding the device - doesn't matter before or after - it will provide the Authentication token within 10 minutes after reboot.
Version 3.0.0.2 (BETA) implemented adding Bond device manually. Simply click green "+" button on Config page. Then enter IP address. The rest should be done automatically.
Version 3.0.0.4 (BETA) - Added Light child devices (incl. Up/Down Lights).
Note 1: Fan Speed/Direction child devices coming - but the parent actions (which don't take arguments) should work for now
Note 2: Not supported devices (i.e. Up/Down Lights in the screenshot) are also created - will make it smarter next version.
[QUOTE=alexbk66;n1356765]Version 3.0.0.5 (in BETA) - Release candidate. Please delete all devices created by previous BETA versions.
Implemented all CF (Ceiling Fan) child devices (Speed, Direction, Lights)
Note: Light Brightness (dimmer) still needs to be implemented, since I don't own a fan with dimmable light.
Working for me (except for dimmer function). Thank you. Elliott
"Living with technology means living in a [constant] state of flux." S. Higgenbotham, 2023
"Reboot and rejoice!" F. Pishotta, 1989
Originally posted by Richel View PostWorking for me (except for dimmer function). Thank you. Elliott
I'm waiting for a week for HST to create a subforum for the plugin, but they are taking their time.
I will add a thread then for feature requests. I still need to add Fireplace support too.
Hi Elliot. Do you have dimmer? I will add the dimer function, but I can't test it myself.
Sorry it's taken me so long to get this posted. I have three different fans that have lights that dim and each one has a different number of speeds (See below screenshots of each fan in the Bond App). I've installed your plugin and it has created the below devices.
I am able to turn the lights on and off for each fan and the "IncreaseSpeed" / "DecreaseSpeed" buttons are properly controlling the fan speeds for each fan.
Notes for each fan:
Media Room:
1) I think I need to call Bond tech support for this fan as the app doesn't seem to be controlling it properly so I'll have to test your plugin for this fan after I get it setup correctly.
2) Is it possible to use increasing numbers for fan speed instead of the slider? I'm thinking that for events it might be easier to set a specific speed?
3) Device Bond.FanDirection only shows "Stop" button but does not have the "Summer" "Winter".....not sure if it was your idea to use those labels but if so, I really like it, very intuitive.
4) Wondering if it's possible to have a "DimUp" / "DimDown" button for lights? This might also be a good place for a slider if possible?
Master Bedroom fan:
1) This fan has an upper and lower light, right now the Bond App doesn't seem to control them correctly so I'll work with them on that as well. I'm hoping that both their app and your plugin will be able to control each of them.
4 PhotosHS4 4.2.6.0 &HSTouch Designer 3.0.80
Plugin's:
weatherXML, Jon00 Alexa Helper, Network Monitor, MyQ, Z-Wave
I will add a thread then for feature requests. I still need to add Fireplace support too."Living with technology means living in a [constant] state of flux." S. Higgenbotham, 2023
