Is there any interest in a plugin for Bond Ceiling Fan controller if I write one?
  • Guest
    Guest replied
    As far as I know the developer is not producing HS plug-ins any longer. To the best of my understanding, he has turned over his current plug-ins to another developer.
    Is that true ? Or you are talking about simplex?
  • cloomis
    Originally posted by The Profit View Post
    This might be a great plugin for spud to do?
    +1
  • bmsmithvb
    I would gladly provide reputable developer with a Bond unit to program a plugin with.
  • The Profit
  • randy
  • bmsmithvb
    @sirmeili - Are you still interested in creating a plugin or was there not enough demand?
  • The Profit
    Originally posted by Peter Wharton View Post
    I'm also interested in testing. I have 2 Minka-Aire fans that use the UC7067 controller and should work with Bond and 4 motorized Somfy shades with RF remotes. If you're creating a plug-in then I'll get a Bond to test with it.
    I don’t think the developer that suggested making an plugin is interested any longer. They haven’t been paying attention to this thread at all.
  • Peter Wharton
  • The Profit
    Originally posted by sirmeili View Post
    ARGH!!!! I wish you lived closer....LOL. I could really use one for testing I'm likely going to buy one, but now hearing all this I'm going to wait until I know the API is released.
    Hello sirmeili I've received an email from Bond indicating that the API has been released, are you still interested in developing a PI for the Bond? Are you waiting until HS4 is released first? Haven't heard much about this PI lately.
    Thank you!
  • AZweimiller
    These were on Woot! yesterday for under $50. I picked one up and am very interested in a plugin.
  • The Profit
    Not yet. I'm about to start back on it. I was holding off waiting for the API to mature, but there is now a work around if it's not there yet.
    Not sure if you've received an email from Bond yet but the email I received this morning introduces an OpenAPI released today. Hoping you will have some time to get this moving again?
    Thank you!
  • Timmy_G
    Hi sirmeili!
    Any update on a plugin mate?
  • The Barnacle
    Spooner Thank you for taking the time to put this little script together. It worked great for me! Cheers!!
  • Spooner
    This is version 2. The virtual device used will work with Alexa and allow you to control a light switch that powers the fan. The commands used to Alexa are "Alexa Master Ceiling Fan 20%" "Alexa Master Ceiling Fan On" "Alexa Master Ceiling Fan Off". If the power switch is off and you ask "Alexa Master Ceiling Fan 20%", it will turn on the switch, wait 5 seconds, and issue the speed command for 20% of 1-6. The On and Off commands only control the light switch.
    Create a virtual device
    Create an event that will monitor the virtual device for any changes.
    The parameters are a comma separated string.
    xxxx,xxxx,bond-device-id,bond-token,name used in log
    Here is a script that works with Bond Bridge v2
    Replace the bond-IP and bond-TOKEN with IP address and Token of your bond device. Both Ver1 and Ver2 are saved with a VB extension, script.vb.
    Both scripting for Ver1 and Ver2 were taken from examples found using google.
    PHP Code:
    Imports System.IO
    Imports System
    .Net
    Imports System
    .Text
    Sub Main
    (parm as object)
    'parms() =
    0Vurtual device ID to monitor;
    '1: Z-wave Device ID on/off switch;
    2Bond device ID            curl -"BOND-Token: bond-TOKEN" -i http://bond-IP/v2/devices
    '3: Bond token                 curl -i http://bond-IP/v2/token
    4Homeseer Device Name used in log
    'bond JSON from http://docs-local.appbond.com/#section/Getting-Started/Getting-the-Bond-Token
    Dim parms()
    Dim dVal
    Dim dSwitch
    const server = "bond-IP"
    If parm Is Nothing Then
       hs.WriteLog("Alexa Fan", "Error; no parameters given " & parm.ToString)
       Exit Sub
    Else
       parms = Split(parm.ToString,",")
    End If
    dVal = hs.DeviceValue(parms(0))
    If (dVal = 0) OR (dVal > 100) Then
       If dVal = 255 Then
         hs.CAPIControlHandler(hs.CAPIGetSingleControl(parms(1), true, "On", false, true))
         hs.WriteLog("Alexa Fan", parms(4)& ": Switch On")
       End If
       If dVal = 0 Then
        hs.CAPIControlHandler(hs.CAPIGetSingleControl(parms(1), true, "Off", false, true))
        hs.WriteLog("Alexa Fan", parms(4)& ": Switch Off")
       End If
       Exit Sub
    Else
       dVal = Decimal.Round((((dVal - 0) * (6-1)) / (100-0)) + 1, 0, MidpointRounding.AwayFromZero)
    If dVal 0 Then dVal 1
       dSwitch
    hs.DeviceValue(parms(1))
       If
    dSwitch 0 Then
        hs
    .CAPIControlHandler(hs.CAPIGetSingleControl(parms(1), true"On"falsetrue))
    hs.WaitSecs(5)
    End If
    hs.WriteLog("Alexa Fan"parms(4)& ": Button " dVal)
    End If
    Dim json_data As String "{""argument"":1}"
    json_data Replace(json_data,"1",dVal)
    ' Create a request using a URL that can receive a post.
        Dim uri As String = "http://" & server & "/v2/devices/" & parms(2) & "/actions/SetSpeed"
        Dim request As Net.HttpWebRequest = Net.HttpWebRequest.Create(uri)
        request.Method = "PUT"
        request.Headers.Add("BOND-Token", parms(3))
        request.ContentType = "application/json"
        Dim json_bytes() As Byte = System.Text.Encoding.ASCII.GetBytes(json_data)
        request.ContentLength = json_bytes.Length
        Dim stream As IO.Stream = request.GetRequestStream
        stream.Write(json_bytes, 0, json_bytes.Length)
        Dim response As Net.HttpWebResponse = request.GetResponse
        Dim dataStream As IO.Stream = response.GetResponseStream()
        Dim reader As New IO.StreamReader(dataStream)          '
    Open the stream using a StreamReader for easy access.
    Dim responseFromServer As String reader.ReadToEnd()  ' Read the content.
    hs.WriteLog("Response"responseFromServer)
    reader.Close()
    dataStream.Close()
    response.Close()
    End Sub
  • Spooner
    This is Version 1 of 2. This device works well without Alexa, Version 2 works with Alexa, and will allow you to set the speed via %.
    Create a virtual device that will control the ceiling fan
    Device Screen 1
    Create an event that will monitor this virtual device for any changes.
    PHP Code:
    Imports System.IO
    Imports System
    .Net
    Imports System
    .Text
    Sub Main
    (parm as object)
    'parms() =
    '1: Bond device ID curl -H "BOND-Token: bond-TOKEN" -i http://bond-IP/v2/devices
    2Bond token curl -i http://bond-IP/v2/token
    '3: Homeseer Device Name used in log
    Dim parms()
    Dim dVal
    const server "bond-IP"
    hs
    .WriteLog("Alexa Fan""Error; no parameters given " parm.ToString)
    Exit
    Sub
    Else
    parms Split(parm.ToString,",")
    End If
    dVal hs.DeviceValue(parms(0))
    hs.WriteLog("Alexa Bond"parms(3)& ": " hs.DeviceVSP_GetStatus(parms(0), hs.devicevalue(parms(0)), 1))
    Dim uri As String "http://" server "/v2/devices/" parms(1) & "/actions/TurnOn"
    Select Case dVal
    Case 100 'off
    json_data = "{""power"":1}"
    uri = "http://" & server & "/v2/devices/" & parms(1) & "/actions/TurnOff"
    Case 101 '
    on
    json_data
    "{""power"":1}"
    uri "http://" server "/v2/devices/" parms(1) & "/actions/TurnOn"
    Case Else
    uri "http://" server "/v2/devices/" parms(1) & "/actions/SetSpeed"
    End Select
    Dim request
    As Net.HttpWebRequest Net.HttpWebRequest.Create(uri)
    request.Method "PUT"
    request.Headers.Add("BOND-Token"parms(2))
    request.ContentType "application/json"
    Dim json_bytes() As Byte System.Text.Encoding.ASCII.GetBytes(json_data)
    request.ContentLength json_bytes.Length
    Dim stream
    As IO.Stream request.GetRequestStream
    stream
    .Write(json_bytes0json_bytes.Length)
    Dim response As Net.HttpWebResponse request.GetResponse
    Dim dataStream
    As IO.Stream response.GetResponseStream()
    Dim reader As New IO.StreamReader(dataStream' Open the stream using a StreamReader for easy access.
    Dim responseFromServer As String = reader.ReadToEnd() '
    Read the content.
    'hs.WriteLog("Response", responseFromServer)
    reader.Close()
    dataStream.Close()
    response.Close()
    End Sub
