Suggestion ► An Echo monitor and control plugin.
  • Suggestion ► An Echo monitor and control plugin.
    I currently use the openhab binding and bing the mqtt payload to hs3..
    . It permits me to do not have to say '' Alexa tell Homeseer to'', and I have perfect room awareness. I have no connection issue and It is faster/more reliable than myhs for calling scene.
    The code (java) is there if anyone is interested to look at it .
    https://github.com/openhab/openhab2-...zonechocontrol
    thanks.
    thanks.
    Do you use Node-RED, MQTT and HomeSeer?
    ===> https://flows.nodered.org/node/node-...ib-amazon-echo
    - Eman.
    The People's Advocate.
      Thanks eman. But Nothing is better than openhab at this . I would like a homeseer plugin like the echo control binding .
      I need : volume control of all echos.
      tts
      last voice spoken to an echo device ( evry echo device would have his device in hs . ) to you can set event based on the string and get room awareness at the same time.
      alarm control
