Device layout to display properly in HS Mobile?
  • #46
    I just don't have time right now to analyze what is going on, I HAVE to get HS4 out the door.
    f you can run the sample plugin and see if that works ok it has a thermostat implementation in it. If that works, you can base your plugin off those devices.
    Same problem.
    Man, I get everybody is busy. Me too, you know.
    • #47
      That ccs_Type is the setpoint sub type:
      Public Enum eDeviceSubType_Setpoint
      Invalid = 0
      Heating_1 = 1
      Cooling_1 = 2
      Furnace = 7
      Dry_Air = 8
      Moist_Air = 9
      Auto_Changeover = 10
      Energy_Save_Heat = 11
      Energy_Save_Cool = 12
      Away_Heating = 13
      End Enum
      Originally posted by alexbk66 View Post
      I looked at Z-Wave code too, what I couldn't work out, which is an important bit.
      DT.Device_SubType = CI.ccs_Type
      public byte ccs_Type
      get
      return mvarSomeType;
      • #48
        The error is an exception, here is the function:
        public void HeatSetPointUpClicked(IThermostatView view) {
        if (HeatSetPointDevice == null) {
        return;
        try {
        var newValue = HeatSetPointDevice.ChangeValue(true);
        view?.SetHeatSetPointText(HeatSetPoint);
        view?.QueueSetPointChange(new ThermostatSetPointChangeEventArgs(HeatSetPointDeviceRef, newValue));
        catch (Exception exception) {
        exception.Log();
        view?.ShowError("Cannot control thermostat. There is a problem with the set-point control configuration.");
        Thank you Rich rjh .
        What "Sample Plugin" do you mean?
        Regarding the error I'm getting "Cannot control thermostat. There is a problem with the set-point control configuration." - Can you please check in your code when it's displayed? May be this will give some clue. But I don't think it's related to "moving all your controls to child devices" in any way.
        • #49
          Where's the log going? LogCat? rjh
          exception.Log();
          • #50
            I assume that code for "CoolSetPointUpClicked" is the same?
            • #51
              Using your sample plugin I get the same error, so for you it should be easy to find why?
              • #52
                Ok, that is odd, but that makes it easy for me to recreate the issue, so let me run that plugin and see what is going on.
                • #53
                  The problem is the "ControlUse" is not set, make sure you set that on your control pairs for the heat and cool setpoints. Which you need to do anyway if you want your thermostat to work with Google Home or Alexa:
                  Pair.ControlUse = ePairControlUse._HeatSetPoint
