Here is version 2.99.0.3 of the HS application:
You can simply run this installer to update an existing HS3 installation.
ftp://ftp.homeseer.com/updates/Beta/...3_2_99_0_3.exe
* This release is for developing plugins, other functions in HomeSeer are not fully tested and will most likely have issues. The UI is not complete. Some features are disabled in this version.
* Only enable one plugin at a time (the device properties will not display properly if more than one is enabled)
Changes:
Version 2.99.0.3
* Fixed status page now displays proper status when using hs.SetDeviceString
Version 2.99.0.2
* No code changes, the installer has changed to include the install for the SQLite files and Visual C++ files
Version 2.99.0.1
* HSEvents are working when using hs.RegisterEventCB
* Some "hs." functions had parameters set to "ByRef", this caused an error and all have been changed to "ByVal"
Version 2.99.0.0
* Search functions in the plugin are not complete
* The HSEvent callbacks in plugins are not working
Changes:
Version 2.99.0.3
Version 2.99.0.2
Version 2.99.0.1
Version 2.99.0.0
