I initially implemented mcsSprinklers for HS3 using RegisterPage and built my pages in the same way I did with HS2 but now using GetPagePlugin and PostBackProc. As part of the implementation buttons existed on the constructed pages that, when clicked, use javascript to open a new browser window and set the url. The url was one of the registered pages (e.g. /weather or weather). That worked fine.
I then migrated the implementation to use RegisterLink for those that I wanted user access and continued to use RegisterPage for those that needed to be serviced outside of the menu system. In this scenario the registered page no longer resulted in a call to GetPluginPage. There was also no call to PutPage, as expected, because there was never a submit from the originally constructed page.
The same lack of GetPagePlugin call results if I simply open a browser and put the URL of one of the registered pages. I get a connecting hourglass where the browser is waiting for a response, but since HS3 never makes a plugin web page call the page never gets built and returned to the browser.
If I enter in the URL a random page (e.g. http://192.168.0.5/fldjadslf) then HS3 returns immediately with only a PowerByHomeseer icon for the page that is linked to www.homeseer.com. The HS3 log also shows file \html\fldjadslf does not exist.
My expectation is that I should be able to use a mixed system of RegisterLink and RegisterPage and have calls to PutPage and GetPluginPage respectively when the URL is set to a page that has been registered(RegisterPage) or included as a menu link (RegisterLink). Since I get different behavior with registered vs. random URL requests it is clear that HS3 recognizes the URL, but does not invoke the plugin to service it.
