Sample Creating a Device
This is a sticky topic.
  • #31
    Originally posted by Rick Tinker View Post
    I just mentioned those in the other thread... They are named differently and are not in a structure in .11 (and I think a release before that) but they have been there for a while. I added ColumnSpan, and when I did that I shortened the names and put all 3 inside a structure. So other than that, the code will work.
    The new feature that caused the change in those is a ColumnSpan giving you more control over the placement of the controls (buttons, sliders, drop-lists) generated from the value/status pairs.
    The render type ValuesSlider I think is in .11 as well - you might like that - especially for relatively low ranges of values (e.g. 0 to 100) it draws a slider rather than drop-downs for selecting dim levels, and in your case, volume levels!
    OK, here is my code and see below how it renders .... Note that the row/column don't seem to do anything.
    I'll do a second posting on a "status device" with a picture of how it renders
    PHP Code:
        Private Function SonosCreatePlayerDevice(ByVal HSRef As IntegerByVal ZoneName As StringZoneModel As StringNewDevice As Boolean) As Integer
    = -1
            Dim dv
    As Scheduler.Classes.DeviceClass
            Dim DevName
    As String ZoneName " - Player"
    Dim dvParent As Scheduler.Classes.DeviceClass Nothing
    Try
                If
    HSRef = -1 Then
                    HSRef
    hs.NewDeviceRef(DevName)
    Log("SonosCreatePlayerDevice: Created device " DevName " with reference " HSRef.ToString " and ZoneModel = " ZoneModelLogType.LOG_TYPE_INFO)
    ' Force HomeSeer to save changes to devices and events so we can find our new device
                    hs.SaveEventsDevices()
                End If
                dv = hs.GetDeviceByRef(HSRef)
                dv.Interface(hs) = tIFACE_NAME
                If NewDevice Then
                    dv.Location(hs) = "Sonos" '
    IFACE_NAME
                    dv
    .Location2(hs) = ZoneName 'IFACE_NAME & InstanceFriendlyName.ToString
                    dv.Device_Type_String(hs) = SonosHSDevices.Player.ToString
                    dv.MISC_Set(hs, Enums.dvMISC.SHOW_VALUES)
                    dv.Can_Dim(hs) = False
                    dv.Image(hs) = ""
                    dv.Buttons(hs) = ""
                    dv.OLD_Values(hs) = ""
                    Dim DT As New DeviceTypeInfo
                    DT.Device_API = DeviceTypeInfo.eDeviceAPI.Media
                    DT.Device_Type = DeviceTypeInfo.eDeviceType_Media.Root
                    DT.Device_SubType_Description = "Sonos Player Master Control"
                    dv.DeviceType_Set(hs) = DT
                    dv.Status_Support(hs) = True
                    hs.SetDeviceString(HSRef, "", False)
    This device is a child devicethe parent being the root device for the entire security system
    ' As such, this device needs to be associated with the root (Parent) device.
                    dvParent = hs.GetDeviceByRef(MasterHSDeviceRef)
                    If dvParent.AssociatedDevices_Count(hs) < 1 Then
    There are none addedso it is OK to add this one.
    dvParent.AssociatedDevice_Add(hsHSRef)
                    Else
    Dim Found As Boolean False
    For Each ref As Integer In dvParent.AssociatedDevices(hs)
                            If
    ref HSRef Then
                                Found
    True
    Exit For
    End If
    Next
    If Not Found Then
                            dvParent
                        Else
    ' This is an error condition likely as this device's reference ID should not already be associated.
    End If
    End If
    ' Now, we want to make sure our child device also reflects the relationship by adding the parent to
    the child's associations.
                    dv.AssociatedDevice_ClearAll(hs)  '
    There can be only one parentso make sure by wiping these out.
    dv.AssociatedDevice_Add(hsdvParent.Ref(hs))
    hs.DeviceVSP_ClearAll(HSRefTrue)
    End If
    Dim ValuePairs As Integer hs.DeviceVGP_Count(HSRef)
    Log("Test in SonosCreatePlayerDevice counting value/graphics pairs. Count =  " ValuePairs.ToStringLogType.LOG_TYPE_INFO)
    hs.DeviceVGP_ClearAll(HSRefTrue)
    Dim Pair As VSPair
                Pair
    = New VSPair(HomeSeerAPI.ePairStatusControl.Control)
    Pair.PairType VSVGPairType.SingleValue
    'Pair.ProtectionSet = ePairProtection.Do_Not_Delete
                Pair.Value = 1
                Pair.Status = "Play"
                Pair.Render = VSVGPairRender.Button
                Pair.ButtonRender_Row = 0
                Pair.ButtonRender_Column = 0
                hs.DeviceVSP_AddPair(HSRef, Pair)
                Pair = New VSPair(HomeSeerAPI.ePairStatusControl.Control)
                Pair.PairType = VSVGPairType.SingleValue
    Pair.ProtectionSet ePairProtection.Do_Not_Delete
                Pair
    .Value 2
                Pair
    .Status "Stop"
    Pair.Render VSVGPairRender.Button
                Pair
    .ButtonRender_Row 0
                Pair
    .ButtonRender_Column 1
                hs
    .DeviceVSP_AddPair(HSRefPair)
                Pair.Value = 3
                Pair.Status = "Pause"
                Pair.ButtonRender_Column = 2
                Pair
    .Value 5
                Pair
    .Status "Prev"
                Pair
    .ButtonRender_Row 0
                Pair
    .ButtonRender_Column 3
                hs
                Pair.Value = 4
                Pair.Status = "Next"
                Pair.ButtonRender_Column = 4
                If ZoneModel.ToUpper = "WD100" Then
                    Pair
    .Value 6
                    Pair
    .Status "BuildDB"
                    Pair
    .ButtonRender_Row 0
                    Pair
    .ButtonRender_Column 5
                    hs
    End If
                Pair.Value = 7
                Pair.Status = "Shuffle"
                Pair.ButtonRender_Row = 1
                Pair
    .Value 8
                Pair
    .Status "Repeat"
                Pair
    .ButtonRender_Row 1
                Pair
                hs
                Pair.Value = 9
                Pair.Status = "Up"
                Pair.ButtonRender_Row = 2
                Pair
    .Value 10
                Pair
    .Status "Dn"
                Pair
    .ButtonRender_Row 2
                Pair
                hs
                Pair.Value = 11
                Pair.Status = "Mute"
                Pair
    .Value 12
                Pair
    .Status "Left"
                Pair
    .ButtonRender_Row 2
                Pair
                hs
                Pair.Value = 13
                Pair.Status = "Right"
                Pair
    .Value 14
                Pair
    .Status "Loudness"
                Pair
    .ButtonRender_Row 2
                Pair
                hs
                Return
    HSRef
    Catch ex As Exception
                Log
    ("Error in SonosCreatePlayerDevice with Error =  " ex.MessageLogType.LOG_TYPE_ERROR)
    End Try
    End Function
    • #32
      This is the second post. This is the code to create status devices and the attached picture shows the icons that I don't want
      PHP Code:
          Private Function CreateHSDevice(ByVal DeviceType As DeviceInfoIndexDevString As String) As Integer
              CreateHSDevice
      = -1
              Dim dv
              Dim DevName
      As String ZoneName " - " DevString
              Dim dvParent
              Dim HSRef
      As Integer = -1
      Try
      HSRef hs.NewDeviceRef(DevName)
                  If
      g_bDebug Then Log("CreateHSDevice for Zone = " ZoneName " created deviceType " DeviceType.ToString " with Ref " HSRef.ToStringLogType.LOG_TYPE_INFO)
      IFACE_NAME
                  dv
                  dv.MISC_Set(hs, Enums.dvMISC.STATUS_ONLY)
                  dv.Image(hs) = ""
                  dv.Buttons(hs) = ""
                  Select Case DeviceType
                      Case DeviceInfoIndex.diTrackHSRef
                          dv.Device_Type_String(hs) = "Track"
                          DT.Device_Type = DeviceTypeInfo.eDeviceType_Media.Media_Track
                          DT.Device_SubType_Description = "Sonos Player Track Name"
                      Case DeviceInfoIndex.diNextTrackHSRef
                          dv.Device_Type_String(hs) = "Next Track"
                          DT.Device_Type = DeviceTypeInfo.eDeviceType_Media.Player_Status_Additional
                          DT.Device_SubType_Description = "Sonos Player Next Track Name"
                      Case DeviceInfoIndex.diArtistHSRef
                          dv.Device_Type_String(hs) = "Artist"
                          DT.Device_Type = DeviceTypeInfo.eDeviceType_Media.Media_Artist
                          DT.Device_SubType_Description = "Sonos Player Artist Name"
                      Case DeviceInfoIndex.diNextArtistHSRef
                          dv.Device_Type_String(hs) = "Next Artist"
                          DT.Device_SubType_Description = "Sonos Player Next Artist Name"
                      Case DeviceInfoIndex.diAlbumHSRef
                          dv.Device_Type_String(hs) = "Album"
                          DT.Device_Type = DeviceTypeInfo.eDeviceType_Media.Media_Album
                          DT.Device_SubType_Description = "Sonos Player Album Name"
                      Case DeviceInfoIndex.diNextAlbumHSRef
                          dv.Device_Type_String(hs) = "Next Album"
                          DT.Device_SubType_Description = "Sonos Player Next Album Name"
                      Case DeviceInfoIndex.diArtHSRef
                          dv.Device_Type_String(hs) = "Art"
                          DT.Device_SubType_Description = "Sonos Player AlbumArt URL"
                      Case DeviceInfoIndex.diNextArtHSRef
                          dv.Device_Type_String(hs) = "Next Art"
                      Case DeviceInfoIndex.diPlayStateHSRef
                          dv.Device_Type_String(hs) = "State"
                          DT.Device_SubType_Description = "Sonos Player State"
                      Case DeviceInfoIndex.diVolumeHSRef
                          dv.Device_Type_String(hs) = "Volume"
                          DT.Device_Type = DeviceTypeInfo.eDeviceType_Media.Player_Volume
                          DT.Device_SubType_Description = "Sonos Player Volume"
                      Case DeviceInfoIndex.diMuteHSRef
                          dv.Device_Type_String(hs) = "Mute"
                          DT.Device_SubType_Description = "Sonos Player Mute State"
                      Case DeviceInfoIndex.diLoudnessHSRef
                          dv.Device_Type_String(hs) = "Loudness"
                          DT.Device_SubType_Description = "Sonos Player Loudness State"
                      Case DeviceInfoIndex.diBalanceHSRef
                          dv.Device_Type_String(hs) = "Balance"
                          DT.Device_SubType_Description = "Sonos Player Balance State"
                      Case DeviceInfoIndex.diTrackLengthHSRef
                          dv.Device_Type_String(hs) = "Track Length"
                          DT.Device_SubType_Description = "Sonos Player Track Length"
                      Case DeviceInfoIndex.diTrackPosHSRef
                          dv.Device_Type_String(hs) = "Track Position"
                          DT.Device_SubType_Description = "Sonos Player Track Position"
                      Case DeviceInfoIndex.diRadiostationNameHSRef
                          dv.Device_Type_String(hs) = "Radiostation Name"
                          DT.Device_SubType_Description = "Sonos Player Radiostation Name"
                      Case DeviceInfoIndex.diTrackDescrHSRef
                          dv.Device_Type_String(hs) = "Track Descr"
                          DT.Device_SubType_Description = "Sonos Player Track Descriptor"
                      Case DeviceInfoIndex.diRepeatHSRef
                          dv.Device_Type_String(hs) = "Repeat"
                          DT.Device_Type = DeviceTypeInfo.eDeviceType_Media.Player_Repeat
                          DT.Device_SubType_Description = "Sonos Player Repeat State"
                      Case DeviceInfoIndex.diShuffleHSRef
                          dv.Device_Type_String(hs) = "Shuffle"
                          DT.Device_Type = DeviceTypeInfo.eDeviceType_Media.Player_Shuffle
                          DT.Device_SubType_Description = "Sonos Player Shuffle State"
                      Case DeviceInfoIndex.diGenreHSRef
                          dv.Device_Type_String(hs) = "Genre"
                          DT.Device_Type = DeviceTypeInfo.eDeviceType_Media.Media_Genre
                          DT.Device_SubType_Description = "Sonos Player Track Genre"
                  End Select
                  dvParent = hs.GetDeviceByRef(HSRefPlayer)
                  Else
                          If
      ref HSRef Then
                              Found
      True
      Exit For
      End If
      Next
      If Not Found Then
                          dvParent
                      Else
      End If
      End If
      WriteStringIniFile("UPnP HSRef to UDN"HSRefUDN)
                  Return
      HSRef
                  Log
      ("Error in CreateHSDevice with Error =  " ex.MessageLogType.LOG_TYPE_ERROR)
      End Try
      End Function
      • #33
        what's the trick for getting an On, Off and value list on the same device; similar to the current hs2 setup
        I can get either the on & off btn or the value list, but not both
        do i need to order the rendering or give them positions?
        Mark
        HS3 Pro 3.0.0.534
        • #34
          Is there another way to render the button?
          I've tried this(VB Code):
          But it says that VSVGPairRender is not defined.
          Since it was used back at 2013 and updates during the last 5 years, is there any other way to render a button?
          This may sound dumb but I am new to Homeseer by the way.
          • #35
            You have to add a reference to the HomeSeer objects (Scheduler, DLL, etc.) and then the Enums will have this. See the sample project (which I assume they still publish) and it should have it in the example.
            Rick Tinker (a.k.a. "Tink")
            • #36
              I've seen the sample. just I need to know what reference to add.
              Since I have included references: HomeSeerAPI, Scheduler, RssToolkit, HSCF, and HomeSeerUtil.
              Is there any other reference must add?
              Also I made a VSVGPairRender variable which is:
              Dim VSVGPairRender As Enums.CAPIControlType
              Still doesn't work.
              Sorry for bugging you just there is an assignment I need to get done.
              • #37
                Alex could you provide the full function that is failing and the actual error message you are seeing?
