HS3 Setup version 2.99.0.11
  • HS3 Setup version 2.99.0.11
    Here is build 2.99.0.11
    Change hi-lights:
    * Changes to plugin API so support mult-instance plugins with single EXE. Your plugins will need to be re-built to work with this version.
    * The installer now installs the source to all 3 of our sample plugins. The source is installed in the application folder in the folder "Sample Plugins". The 3 samples are:
    1) HSPI_SAMPLE (the standard sample with robust triggers/actions)
    2) HSPI_SAMPLE_BASIC (A more basic plug-in with simple actions/triggers)
    3) HSPI_SAMPLE_BASICMI (Based on the sample basic, this adds support for multiple instances using 1 EXE) (See the seperate thread for details on multi instancing)
    NOTE: Do not install any of the plugins from the updater, they are not functioning at this time and they exist only for our in-house testing.
    Here is the installer:
    ftp://ftp.homeseer.com/updates/Beta/...S3_2_99_11.exe
    It looks like ClearINISection() is no longer working in this version.
    Also, SaveINISetting() converts the "section" parm to uppercase?
    Can anyone else confirm?
      INI code was re-written for compatibility with Linux.
      Yes, the section name is converted to upper case, should not matter though as its not case sensitive.
      I will look at ClearINISection.
        ClearINISection is fixed, the fix will be in the next update.
          I'm getting a 30 day trial msg when i start 2.99.0.11?
          Do i need to worry about this or will the next version restart the clock?
          Mark
          HS3 Pro 3.0.0.534
            Same here ....
            Dirk
              Installed .11 this morning. I don't see any expiration message when HS starts up.
              HS Pro 3.0 | Linux Ubuntu 16.04 x64 virtualized under Proxmox (KVM)
              Hardware: Z-NET - W800 Serial - Digi PortServer TS/8 and TS/16 serial to Ethernet - Insteon PLM - RFXCOM - X10 Wireless
              Plugins: HSTouch iOS and Android, RFXCOM, BlueIris, BLLock, BLDSC, BLRF, Insteon PLM (MNSandler), Device History, Ecobee, BLRing, Kodi, UltraWeatherWU3
              Second home: Zee S2 with Z-Wave, CT101 Z-Wave Thermostat, Aeotec Z-Wave microswitches, HSM200 occupancy sensor, Ecolink Z-Wave door sensors, STI Driveway Monitor interfaced to Zee S2 GPIO pins.
                will tomorrow.
                  Licensing is not final, for now, you can just delete the licenses.bin file in the config folder and that will restart the trial timer.
                    Well now it disabled itself ....
                    3/18/2013 7:27:41 AM - Warning - This version of HomeSeer is not registered and is currently disabled
                    Dirk
                    postedit: when I restarted HS3, it began another 30 day trial ....... and is working
                      Shut down HS, delete the file, start HS. If says its disabled, restart HS again, should be on a 30 day trial.
                      Dirk
                        the performance of this new code is slow; specifically getinisetting
                        Mark
                        HS3 Pro 3.0.0.534
                          How are you testing the performance? Are you reading a lot of values?
                            Yes, in my dev env, i have an ini file with more than 700 lines that takes more than 15 secs to load/process; compared to less than 1 second in hs2 for the exact same load/process routine.
                            Mark
                            HS3 Pro 3.0.0.534
                              I took a quick look and the issue is probably the fact that its reading the entire file everytime you get or set an entry, I'll put a fix in for that.
