jqButton with AddScript()
  • jqButton with AddScript()
    Since we still cant search this forum, I'll post the question here - not sure if it has been covered...
    I have a jqButton defined and am trying to call a script for the onClick:
    PHP Code:
    Dim b As New clsJQuery.jqButton("btnTestConnection""Test Connection"IFACE_NAMEFalse)
    b.AddScript("function userConfirm() {  confirm(""hey - are you sure??"");  }")
    b.functionToCallOnClick "userConfirm()"
    sbtb.Append(b.Build
    When it builds the page, I see in the source view that the function is built, but the button does not have an onClick property and the script never gets called. For that matter, I do not see the confirm("hey are you sure??") in there either...
    PHP Code:
    <script>
    $(function() {
    '#btnTestConnection_ID598385').button({icons: {primary:'',secondary:''} });
    '#btnTestConnection_ID598385').click(function() {
    userConfirm()
    var
    theData='';
    returnTrue false
    theData
    theData+'&id='+this.id+'&btnTestConnection=Submit';
    commonAjaxPost(theData,'My Plugin');
    if(
    returnTrue) {
    location.reload();
     return
    false;
    else {
     return
    false;
    script>
    button type='submit'   id='btnTestConnection_ID598385'  name='btnTestConnection' >Test Connection</button
    So, how should we use AddScript to have a jqButton call a script?
    It looks like you need to set the includeClickFunction to true as well.
    Wade
    I know nothing...., nothing!!!
      I added that property and the generated code still is not bringing over my function from the AddScript:
      PHP Code:
      b.includeClickFunction True
              sbtb
      .Append(b.Build
      When I do a view/source, this is the script area for the button:
      PHP Code:
      <script>
      $(function() {
      userConfirm()
      var
      theData='';
      returnTrue false
      theData
      commonAjaxPost(theData,'MyPlugin');
      if(
      returnTrue) {
      location.reload();
       return
      false;
      else {
       return
      false;
      script>
      It looks to be the same as before - no effect on includeClickFunction=True
      Am I right in thinking that this is how AddScript works with the jqButton?
        you could add this as a string after adding button build.
        addscript isnt documented, is it like you see it or is it a reference to a script file.
        PHP Code:
        <script type='text/javascript'userConfirm() {  confirm(""hey are you sure??"");  }</script
          PHP Code:
          Yes, that adds the script code, but it never gets called. I think if it somehow does get called, the post/postback will still occur regardless if you press ok or cancel.
          I dont believe AddScript references a file - my assumption is that it allows you to do some inline js for jquery. Since it's not documented, that is a big assumption
          HST - we really would like some way to prompt the user with "Are you sure?" for jqButton.
            The problem is the script variable is being cleaned just prior to building the object.
            Adding your script to the top of your page should fix this.
            Wade
              Excellent - thanks Wade!
                Did you guys finally got this confirmation box/function to work?
                Thanks for sharing
                Dirk
                  Almost 7 years after and I have the same problem. How to implement a "Are you sure dialog". Does anyone have a some code to show me?
                    I made my own solution
                    https://forums.homeseer.com/forum/de...77#post1354977
