HS3 Setup version 2.99.0.16
  • #16
    Originally posted by dcorsus View Post
    I also noted that in previous versions the section names were converted to all capitals. In this version, it is back to be case sensitive, so in my case, my .ini file, had all sections renamed to all capitals and with this version all failed. No biggie, just wanted to let other know.
    Confirmed - it's case-sensitive in this version...
    68 Z-Wave Nodes, 174 Events, 326 Devices
    • #17
      Click run 30 day trial ......
      If only I had that option.
      • #18
        Licensing is not final, for now, you can just delete the licenses.bin file in the config folder and that will restart the trial timer. you can also download version 16
        __________________
        • #19
          You dont get this option?
          • #20
            No, only the two last options, "instant online registration" or "manual registration".
            Ah, I'll delete the .bin file, thanks!
            • #21
              I have not attempted this version yet. Was there a lot of plugin changes that require recompiles with .16?
              Cheers,
              Bob
              • #22
                Only thing I ran into was the row/column changes on device buttons which was a breeze and now works
                Dirk
                • #23
                  I don't believe there are any changes that would affect your plugins.
                  • #24
                    Thanks. Good to know.
                    Cheers,
                    Bob
