Issue with button press response in v.16 ??
  • Issue with button press response in v.16 ??
    Has anybody experienced an issue where clicking on buttons in the DeviceUtility page doesn't call your plugin anymore?
    Haven't had the time to try to figure out how and when it happens, but a few times, I found my buttons to be unresponsive, even refreshing the page made no difference. I noted a Device Control entry in the HS log but the PI received no call back. When I stopped the PI (I was using Visual Studio) and restarted it, it would work a bit and then stop again.
    Anybody else seen this?
    Dirk
    Dirk,
    did you figure this out? is hs calling setiomulti instead of setioex now
    Mark
    HS3 Pro 3.0.0.534
      Originally posted by mnsandler View Post
      Dirk,
      Didn't see it again, suspect it might have something to do with doing on-line debugging and stopping the program and restarting it many times. Have to admit that I haven't been doing a whole lot on my plugin either.
      As far as I can tell HS3 calls SetIOMulti.
      Dirk
