Latest HS3 Setup
    Latest HS3 Setup
    [UPDATE 5/29/13]
    Since the BETA has been posted, get the latest Beta from either running your current version (you will be prompted if an update is available), or get the setup file from the HS3 Beta forum on the message board.
    [UPDATE 5-27-13]
    Starting with build 2.99.0.34 licensing has changed. You can no longer simply delete the licenses.bin file to restart the trial. If your trial expires, you may use the following trial key which starts a 30 trial trial for the PRO version:
    LicenseID: 55152
    Password: trial
    Also, builds 2.99.0.34 and later contain a new application updater, so simply restart HS and it will check for updates and notify you if an update is available.
    As we get very close to our public Beta release we are building HS3 pretty much daily. I am uploading the latest build as I create them. Note that they are not tested before uploading so it is possible that the build may not work. Save your previous one in case you need to go back.
    The latest build will always be available at this ftp link:
    Feel free to post any issues you find to help us provide the best Beta possible. Each build will have a new version #.
    We have opened bugzilla for bug reports, this is the best way to report a bug as we will be notified about it immediately. You can create an account and create bug reports here:
    http://homeseer.com/bugzilla
    Rich,
    Are you going to put some form of wrapper around scripts to show errors?
    If I purposely create an error, nothing shows in the log; it just shows that it has executed.
    Jon
      Anyone else having trouble getting HS3 Setup? My browser stalls on the load.
      Don
        Is this a vbscript or vb.net script?
        Originally posted by jon00 View Post
        Rich,
          Don - try a right-click and Save As and see if you can save it to your desktop.
          68 Z-Wave Nodes, 174 Events, 326 Devices
            Vb.net
            Jon
              Got it....
              Don
                What license and ID can I use to test?
                  On the test build just delete the licenses.bin file to restart the trial.
                    what happened to the ftp link?
                    do we really need to go through the store to get the latest beta? PITA!
                    Mark
                    HS3 Pro 3.0.0.534
                      I agree
                        You only need to go through the store once! After that, just restart HS3, it does an update check and will download the new version automatically. You can save the download file if you want to install the latest on another system.
                          I installed the version from the store 3.0.0.2. why does it keep asking me to install the same update version 3.0.0.2?
                          Mark
                          HS3 Pro 3.0.0.534
                            It should not be doing that, I ran 3.0.0.2 here and its not asking, anyone else seeing this?
                              Yes, I get the same here.
                              I also get a failure with update notice, even though it updates fine. If you let the updater shutdown homeseer 3 and the speaker client, it then errors stating that an application is still running (but it is not - I checked with task manager). Next it states it cannot remove the short cuts, you acknowledge the error and then the short cuts are removed? You then get the failure notice.
                              Jon
