[UPDATE 5/29/13]
Since the BETA has been posted, get the latest Beta from either running your current version (you will be prompted if an update is available), or get the setup file from the HS3 Beta forum on the message board.
[UPDATE 5-27-13]
Starting with build 2.99.0.34 licensing has changed. You can no longer simply delete the licenses.bin file to restart the trial. If your trial expires, you may use the following trial key which starts a 30 trial trial for the PRO version:
LicenseID: 55152
Password: trial
Also, builds 2.99.0.34 and later contain a new application updater, so simply restart HS and it will check for updates and notify you if an update is available.
As we get very close to our public Beta release we are building HS3 pretty much daily. I am uploading the latest build as I create them. Note that they are not tested before uploading so it is possible that the build may not work. Save your previous one in case you need to go back.
The latest build will always be available at this ftp link:
Feel free to post any issues you find to help us provide the best Beta possible. Each build will have a new version #.
We have opened bugzilla for bug reports, this is the best way to report a bug as we will be notified about it immediately. You can create an account and create bug reports here:
http://homeseer.com/bugzilla
[UPDATE 5-27-13]
LicenseID: 55152
Password: trial
