CAPIControl Buttons ?
    I have created devices that show up in the Device Management tab page with buttons and when the buttons are pressed I get an indication that they were pushed but how/where is the the code that gets executed? In HS2 we had functions like ButtonPressed() to deal with the code for the buttons. What do we use now? This is the code used to create buttons:
                Pair = New VSPair(ePairStatusControl.Both)   ' This is what appears in the device actions...
                Pair.PairType = VSVGPairType.SingleValue
                Pair.Value = 0
                Pair.Status = "OFF"
                Pair.Render = Enums.CAPIControlType.Button
                If Not hs.DeviceVSP_AddPair(dvRef, Pair) Then
                End If
                Pair.Value = 1
                Pair.Status = "ON"
                End If
    What would the code look like?
    -Larry
    A member of "The HA Pioneer Group", MyWebSite
    Plugins:
    VWS, AB8SS, lrpSpeak, Calendar, Arduino, Harmony, BlueIris, Sprinklers, ZipBackup...
    Hardware:
    Intel NUC8i7BEH1 running Windows 10 Pro headless, HS3 Pro, Plex running on Synology dual High Availability DS-1815+ NAS (24Tb each), Synology Surveillance Station running on DS-416 Slim (8Tb), Samsung SmartThings, Google Home, Alexa, Hubitat Elevation, ZNET, Ubiquiti UniFi Network, Davis Vantage Pro II Weather Station. Whole house speaker system using a couple of AB8SS switches. Vantage Pro II Weather Station, Rain8Net Sprinklers, Hubitat Elevation, Google Home, Alexa, DSC Security System, Ubiquiti UniFi Network.
    You want to use SetIOMulti()
    It will send you a list of the CAPIControl objects. You then iterate through and grab the device reference id to do what you want.
    68 Z-Wave Nodes, 175 Events, 359 Devices
      Thanks that did the trick.
      -Larry
      Plugins:
      Hardware:
