Speak Proxy
    Speak Proxy
    Does anyone has successfully implemented a speak proxy plugin with HS3?
    I can't make it work:
    in InitIO I register the plugin as a speak proxy like this:
    hsCallback.RegisterProxySpeakPlug(IFACE_NAME, "");
    and in my HSPI class I have a SpeakIn function:
    public void SpeakIn(short device, string text, bool wait, string host = "")
         //my speak proxy logic
    but when I run a speak action this function is never called, and I get this error in the log:
    23/05/2013 3:11:44 PM  - Error - In SpeakDev SpeakProxy: Object does not match target type.
    Just saw this one...
    I am having the same problem, did you ever find a solution?
    -Larry
    A member of "The HA Pioneer Group", MyWebSite
    Plugins:
    VWS, AB8SS, lrpSpeak, Calendar, Arduino, Harmony, BlueIris, Sprinklers, ZipBackup...
    Hardware:
    Intel NUC8i7BEH1 running Windows 10 Pro headless, HS3 Pro, Plex running on Synology dual High Availability DS-1815+ NAS (24Tb each), Synology Surveillance Station running on DS-416 Slim (8Tb), Samsung SmartThings, Google Home, Alexa, Hubitat Elevation, ZNET, Ubiquiti UniFi Network, Davis Vantage Pro II Weather Station. Whole house speaker system using a couple of AB8SS switches. Vantage Pro II Weather Station, Rain8Net Sprinklers, Hubitat Elevation, Google Home, Alexa, DSC Security System, Ubiquiti UniFi Network.
      no, but Rich said he will look into it
        The Beta is now out, and this issue should be fixed in it.
        Wade
        I know nothing...., nothing!!!
          thanks, it works now.
            Doesn't work for me.
            Error 1 Class 'HSPI' must implement 'Sub SpeakIn(device As Integer, txt As String, w As Boolean, host As String)' for interface 'HomeSeerAPI.IPlugInAPI'. C:\Users\Larry\Documents\Visual Studio 2010\Projects\HomeSeer3\hspi_lrpSpeak 1.0.0.0 05-25-2013 - Working\hspi.vb 8 16 hspi_lrpSpeak
            Here is my code is hspi.vb
            Public Sub SpeakIn(ByRef device As Short, ByRef txtSTR As String, ByRef wait As Boolean, ByRef host As String)
                    oPlugin.SpeakIn(device, txtSTR, wait, host)
            End Sub
            and in plugin.vb
                    Dim i As Short
                    ' my code here
                    ' Tell HomeSeer to speak the stuff
                    hs.SpeakProxy(device, txt, False, "")
            End Sub
            -Larry
            Plugins:
            Hardware:
              Another note...I even get this error in plugins that do not even register with callback.RegisterProxySpeakPlug(IFACE_NAME, Instance)???
              -Larry
              Plugins:
              Hardware:
                First parameter of SpeakIn is now an Integer, not a Short anymore
                  Thanks I figured it out after my post...everything seems to be working now.
                  -Larry
                  Plugins:
                  Hardware:
