Where did StringItem go ???
  • Where did StringItem go ???
    The HS3 - Developer Documentation still shows StringItem as a legitimate Function under Scripting/Strings, Global Variables, and Encryption/StringItem, when used in code the editor gives this error:
    Error 1 'stringItem' is not a member of 'HomeSeerAPI.IHSApplication'.
    Is this function still available in HS3?
    -Larry
    A member of "The HA Pioneer Group", MyWebSite
    Plugins:
    VWS, AB8SS, lrpSpeak, Calendar, Arduino, Harmony, BlueIris, Sprinklers, ZipBackup...
    Hardware:
    Intel NUC8i7BEH1 running Windows 10 Pro headless, HS3 Pro, Plex running on Synology dual High Availability DS-1815+ NAS (24Tb each), Synology Surveillance Station running on DS-416 Slim (8Tb), Samsung SmartThings, Google Home, Alexa, Hubitat Elevation, ZNET, Ubiquiti UniFi Network, Davis Vantage Pro II Weather Station. Whole house speaker system using a couple of AB8SS switches. Vantage Pro II Weather Station, Rain8Net Sprinklers, Hubitat Elevation, Google Home, Alexa, DSC Security System, Ubiquiti UniFi Network.
    It looks like it was moved to the Scheduler classes:
    Dim sHs As Scheduler.hsapplication
    sHs.StringItem(mystring, 1, ",")
    I hope thats an oversight - it probably belongs in the HomeseerAPI class. You might want to enter a bug report at: www.homeseer.com/bugzilla
      It will not be included in HS3 when I asked the same question: http://board.homeseer.com/showthread.php?t=158301
      Jon
        ah - I think I remember seeing that post. Thanks Jon...
          You can use the .split function of the String object.
          -Rupp
            I thought split only works with a single character separator?
            hs.stringitem (and my replacement Regex function) works with any string as the separator.
            Jon
              Would you care to share the Replacement function?
              -Larry
              Plugins:
              Hardware:
                Split works with chars and strings. ie 4th and 6th overloads.
                -Rupp
                  Here you go:
                  PHP Code:
                      Function Stringitem(ByVal Str As StringByVal Index As IntegerByVal Sep As String) As String
                  Try
                  Dim Result() As String System.Text.RegularExpressions.Regex.Split(StrSystem.Text.RegularExpressions.Regex.Escape(Sep))
                              Return
                  Result(Index 1)
                          Catch
                              Return
                  End Try
                  End Function
                  Jon
                    Here you go:
                    PHP Code:
                    Try
                                Return
                    Result(Index 1)
                            Catch
                                Return
                    End Try
                    End Function
                    Thank you so much Jon00
                    -Larry
                    Plugins:
                    Hardware:
                    Unconfigured PHP Module
