Failed Getting InterfaceStatus
I compiled the samples without changing any code and then copy the executable to the HS3 folder. When I restart HS3 and go to the plugin manager I get the following warnings for the two samples I installed:
WARNING: Failed getting InterfaceStatus from Sample Plugin - the interface was not found in the list of active interfaces, the list may need to be refreshed.
What causes this and how do I avoid that.
Also the Sample-BasicMI under "Instance" shows "See plug-in config" but the plugin has not configuration website (the plug-in name is not an URL and the plug-in is not listed under the menu "PLUG-INS").
HS3 Plugin Samples
This is a sticky topic.
Mine has been available for a while, but not in C#.
http://board.homeseer.com/showthread.php?t=177339
Sorry Moskus, I couldn't wait any longer and ended up make my own barebones C# sample plugin. It really only addresses instantiating and connecting the plugin to Homeseer HS3, but it is far simpler (and I hope more sensible) than the official samples.
Thread here: http://board.homeseer.com/showthread.php?t=178122
If you are talking about mine, then:
"Very soon", I hope. I've just discovered some parts I want to rewrite, but it is soon ready for first release.
Hi Moskus, I'm keen to see your simplified base plugin as I have several HS2 plugins of my own to port across.
I thought I was a pretty reasonable hobby programmer but the new SDK and sample projects scare me. They seem really convoluted, there is an awful lot of glue code to tie all of the classes together and I would have though that could be abstracted away in the SDK rather than being reproduced in every plugin.
Anything that simplifies them will be a huge help.
Originally posted by beerygaz View PostThe other sample plugin has two "helper" procedures which I find useful. Note that they also "remove" the current object before adding it to ensure it's replaced and not added to all the time. These could easily be modified for unnamed objects too.
Why are they serializing it before adding? Shouldn't the class handle that itself?
Code:Sub PEDAdd(ByRef PED As clsPlugExtraData, ByVal PEDName As String, ByVal PEDValue As Object) Dim ByteObject() As Byte = Nothing If PED Is Nothing Then PED = New clsPlugExtraData SerializeObject(PEDValue, ByteObject) If Not PED.AddNamed(PEDName, ByteObject) Then PED.RemoveNamed(PEDName) PED.AddNamed(PEDName, ByteObject) End If End Sub Function PEDGet(ByRef PED As clsPlugExtraData, ByVal PEDName As String) As Object Dim ByteObject() As Byte Dim ReturnValue As New Object ByteObject = PED.GetNamed(PEDName) If ByteObject Is Nothing Then Return Nothing DeSerializeObject(ByteObject, ReturnValue) Return ReturnValue End Function
Code:Public Function SerializeObject(ByRef ObjIn As Object, ByRef bteOut() As Byte) As Boolean If ObjIn Is Nothing Then Return False Dim str As New MemoryStream Dim sf As New Binary.BinaryFormatter Try sf.Serialize(str, ObjIn) ReDim bteOut(CInt(str.Length - 1)) bteOut = str.ToArray Return True Catch ex As Exception Log.Error(IFACE_NAME + " Error: Serializing object " + ObjIn.ToString + " :" + ex.Message, ex) Return False End Try End Function Public Function DeSerializeObject(ByRef bteIn() As Byte, ByRef ObjOut As Object) As Boolean ' Almost immediately there is a test to see if ObjOut is NOTHING. The reason for this ' when the ObjOut is suppose to be where the deserialized object is stored, is that ' I could find no way to test to see if the deserialized object and the variable to ' hold it was of the same type. If you try to get the type of a null object, you get ' only a null reference exception! If I do not test the object type beforehand and ' there is a difference, then the InvalidCastException is thrown back in the CALLING ' procedure, not here, because the cast is made when the ByRef object is cast when this ' procedure returns, not earlier. In order to prevent a cast exception in the calling ' procedure that may or may not be handled, I made it so that you have to at least ' provide an initialized ObjOut when you call this - ObjOut is set to nothing after it ' is typed. If bteIn Is Nothing Then Return False If bteIn.Length < 1 Then Return False If ObjOut Is Nothing Then Return False Dim str As MemoryStream Dim sf As New Binary.BinaryFormatter Dim ObjTest As Object Dim TType As System.Type Dim OType As System.Type Try OType = ObjOut.GetType ObjOut = Nothing str = New MemoryStream(bteIn) ObjTest = sf.Deserialize(str) If ObjTest Is Nothing Then Return False TType = ObjTest.GetType 'If Not TType.Equals(OType) Then Return False ObjOut = ObjTest If ObjOut Is Nothing Then Return False Return True Catch exIC As InvalidCastException Return False Catch ex As Exception Log.Error(IFACE_NAME + " Error: DeSerializing object: " + ex.Message, ex) Return False End Try End Function
I don't think the CObj is necessary in your case, you could probably remove it and it would still work. (maybe). but you did get me thinking, since it's being sent to homeseer over HSCF maybe a complex object needs to be serialized.
This appears to work.
Code:'set the EDO for device amp1 Dim EDO As New HomeSeerAPI.clsPlugExtraData dv.PlugExtraData_Set(hs) = EDO 'Dim HW As String = "a1" Dim HW As New MyDeviceData() HW.mydevice = MyDeviceData.mydevices.Amp1 Dim bteArray() As Byte = Nothing If Not SerializeObject(HW, bteArray) Then Throw New Exception("Not able to Serialize myaction data in actionbuildui.") 'Dim Ret As New IPlugInAPI.strMultiReturn 'Ret.sResult = "" ' Empty return indicates success! 'Ret.TrigActInfo = ActInfoIN ' Trig info does not change, just pass through what we received... ' Ret.DataOut = bteArray If EDO.GetNamed("My Device Object") IsNot Nothing Then EDO.RemoveNamed("My Device Object") End If EDO.AddNamed("My Device Object", bteArray) ' Need to re-save it. dv.PlugExtraData_Set(hs) = EDO hs.SaveEventsDevices()
Originally posted by mrhappy View PostThis is what I did but no idea whether or not it is the correct approach, it works though.
Code:Select Case k Case 1 To 4 With EDO .AddNamed("enAPIDirection", CObj("Consumed")) .AddNamed("enAPIDevice", CObj("Meter_Service")) .AddNamed("enAPILog", CObj("True")) End With 'use this opportunity to do some Energy API work hs.Energy_SetEnergyDevice(dv.Ref(hs), enumEnergyDevice.Meter_Service) End Select dv.PlugExtraData_Set(hs) = EDO
This is a problem with the SDK and plugin development in general, and with PlugExtraData specific. The more people you ask, the more options you get...
I just have to sort out some SubTriggers, and I'll revisit the PlugExtraData issue as I've been meaing to look into it again. (I don't fully understand it, and that club is getting bigger every day it seems).
Originally posted by happnatious1 View PostBelow is what I ended up with, It's basically right out of the sample_plugin. If someone can point me to a sample using an object I'd be appreciative.
Code:'set the EDO for device amp1 Dim EDO As New HomeSeerAPI.clsPlugExtraData dv.PlugExtraData_Set(hs) = EDO Dim HW As String = "a1" If EDO.GetNamed("My Device Object") IsNot Nothing Then EDO.RemoveNamed("My Device Object") End If EDO.AddNamed("My Device Object", HW) ' Need to re-save it. dv.PlugExtraData_Set(hs) = EDO hs.SaveEventsDevices()
The good news is I now have a partially functioning plugin for my monoprice 6 zone amplifier. Truth be told I never thought I'd make it this far. The only thing left is triggers and a lot of typing to add the rest of my functionality.
Originally posted by Moskus View Post... and the plugin samples are storing custom classes...
Did changing type solve your problem?
Originally posted by SteveMSJ View PostI wish I was as organised as you. I found it a long learning curve working through the basic plugin samples to understand how things work when writing my own plugin. Whilst I cracked most of it, or at least the bits I needed, I suspect that when I start another plugin project after a few months gap I will have forgotten most of what I learnt
Your work will be very useful to us all.
Steve
I've already exeeded my own requirements for the first couple of plugins I want to make, but I know I will hit the wall just after that, so I keep testing and developing my sample project.
Keep in mind that it is based on the basic sample, so the very advanced stuff won't be coverede (at least not at first).
I'm hoping to make it a more living sample, updating it while I code.
And the downside is that is that it's based on my interpretation of the SDK. Just being a hobby-developer might cause me to make mistakes. Hopefully others will find them and correct me.
Together I'm sure we can make a good sample plugin.
Steve
Originally posted by Moskus View PostRight now I'm taking the basic plugin sample and simplifies it a little more. I'm adding comments and renaming variables so that the code is easier to read, so that we stand a chance of understanding what's going on.
I really admire HomeSeer for what they have done, and what they enable for plugin developers. The posiblilites are really endless!
But the code structure of the samples are... uhm... unstructured in my opinion. I'm used to reading SDKs (for Steam, Fitbit, Universal apps for Windows 10, etc), and while the possiblities are many in HomeSeer, the sample code and the code base is also somewhat messy and confusing.
Examples:
Hungarian notation. It's now abandoned by everyone (except old VB coders) at least 10 years ago. Hungarian notation is when you put the string type in front of the variable, so that it's easier to get the variable you want and the idea is that it makes the code easier to read.
That might well be before .NET, but now it's not a problem. Now the recommendation is that if you really have to include the variable type, then add it to the end of the name. So "strName" becomes "NameString".
The main problem is when variables, especially global variables, changes types. This is not uncommon when you start coding. You create a variable called "strLocation" because it is the name of a location and it's a string. As you keep coding, you see that you are not only passing the location name around, but also the GPS location with latitude and longitude, so you create your own class to pass all of this information around:
Code:Public Class Location Public Property Name As String Public Property Latitude As Double Public Property Longitude As Double End Class
I've used Hungarian notation myself. And now when I have to update my old programs, I can see that even my own code, which I am very familiar with, is pretty darn hard to understand sometimes.
Abbreviations. Again something from the "good, old days" before Visual Studio had proper IntelliSense (auto completion) and people coded in Notepad or whatnot. Typing long words was "a vaste of time".
But that results in classes named such as strActTrigInfo that perpahs started out as a string holding Action and/or Trigger information? I have no idea.
Commenting. Perhaps the most important part of any programming project. Escpecially when you are to show your work others. Like in a SDK!
There's no magic way to make a fellow programmer understand how you think. You need to tell him/her. One way is to avoid abbreviations and don't use Hungarian notation, but comments are even more important.
The sample projects have almost no comments!
Some statistics:
- The main sample has 596 lines containing comment marks ( ' ).
- The basic sample has 150 lines containing comment marks.
- My basic sample has 816 lines containing comment marks, and I'm not even done yet!
I'm going through the basic sample line for line, adding comments from the SDK on the web directly and adding comments on my own so that I better understand what's going on.
I understand commenting on a sample plugin is way down on HSTs priority list. I just wish they had done it when they were coding it, it would have made it so much easier to understand.
I want to understand the SDK. That's why I do this. But I don't see why I shouldn't help others getting started with plugins as well. Ultrajones made a similar sample for HS2, and I wouldn't have gotten into plugins at all if it weren't for him. I'm just paying it forward.
Originally posted by happnatious1 View PostSo after some more reading and another look at the plugin sample and some experimentation I've come to the conclusion that the PlugExtraData object can only be fed simple base types such as strings and integers. You can not feed it an actual object, or an enum, or maybe even an array. There also appears a plugextradataV2 within intellisense, but that appears to be anybody's guess as to what it does.
Steve
