Just updated to 3.0.0.11...still getting a failed installation but it works
    however, the next time i run hs it asks me to upgrade to 3.0.0.11 again
    how to fix this?
    Mark
    HS3 Pro 4.2.19.5
    for the record I get the same results on a new installation on a pc that never had hs installed.
    I started with 3.0.0.2 and the got the msg to upgrade to 3.0.0.11 and get a failed msg after it installed. and then I continue to get the update to 3.0.0.11 on restart
    this is really annoying. can some help me resolve this!
    Mark
    HS3 Pro 4.2.19.5
      Mark - dont quote me on this, but I think it has to do with installing HS3 in a non-default folder, maybe even on a different drive? Are you letting the install go to the default folder? What about 32-bit vs 64-bit?
      HS4Pro on a Raspberry Pi4
      54 Z-Wave Nodes / 21 Zigbee Devices / 108 Events / 767 Devices
      Plugins: Z-Wave / Zigbee Plus / EasyTrigger / AK Weather / OMNI
      HSTouch Clients: 1 Android
        you might be onto something with the default folder. I installed into \Homeseer 3
        i've installed 32 and 64 bit into the same folder name with the same results
        Rick/Rich,
        Can you fix this please?
        Mark
        HS3 Pro 4.2.19.5
