HSPI_Marquis_Monoprice_Amp v3.0.0.15.zip A free HS3 plugin to control Monoprice 6 zone amplifiers. 3 amps can be daisy chained for up to 18 zones. HSPI_Marquis_Monoprice_Amp v3.0.0.15.zip
Actions are in a target, command, value structure such as "zone 1, power, off"
It also has 3 virtual actions:
PA_ON , switches all zones currently on to source 1
PA_Off, switches all sources back to where they were when PA_ON was called.
Public_Announcement ON/OFF Saves the current state of power and source for each zone, turns on zones with check marks, switches all zones to source 1.
Private_Announcement ON/OFF Saves the current state of power and source for each zone, turns on zones with check marks, Switches only the zones with check marks to source 1.
Here is a typical private announcement event: Notice the 1 second delay giving the amp time to power up a zone and the wait for speech to finish check mark so that the tts can finish.
Version 3
the only supported version moving forward. Free. 3 amps. 18 zones. Linux compatible. Seems to work as legacy plugin on HS4 as well.
Version 3
