Moen
    Moen
    Hello
    can anyone make the Moen S3104
    work will home see
    or if there is a cheaper way
    I have the elk m1 gold
    thank you
    If you can control this hardware via IFTTT then you should be able to use HS3 to interface with the hardware.
    -Rupp
      Any update on this? Was anyone able to integrate the Moen U and S3104 valve with HS3 or HS4. Buying this and installing this month.
