OK - VPN back to home was up - and I have cut a recompiled version on the OCX - I am thinking that there is some mix up between older versions and newer versions and I really don't know what is breaking but....
Try this (backup 1st just in case)
Unregister the existing hspi_malk8055.ocx file, then rename it to something else - like "notworkingmalk8055.ocxnot"
Unregister the mcsxap ocx
Re-register the mcsxap ocx (assuming mcsxap is an ocx)
Try HS - does mcsxap work/start OK?
Shutdown homeseer
Unzip the attached ocx into the homeseer directory - register it
Try HS again
NOTE: No functionality changes in this version, just a recompile with the compatability stuff turned off to make it create a new guid.
Let me know....
Malarcy
Shutdown homeseer
Try HS again
Let me know....
Malarcy
