tenHsEvents Monitors Device Changes in Real Time (need beta testers)
  • #31
    Same.
    Control works before, and while i use the program. But after , I can control individual device, but not multiple device wich are mapped to one devices ( ex : my hallway virtual device turn of anything in the hallway. Now , it doesnt. But i am able to control the device individually.
    And my motions events don't fire
    • #32
      Originally posted by MattL0 View Post
      Same.
      Would you please try this test version: http://tenholder.net/temp/tenHsEventsTest.zip
      Log records will not be recorded.
      tenholde
      tenholde
      • #33
        Will do tomorow. I need to monitor a plugin until tomorow on my system
        • #34
          I have open/closed the app 3 times, and there is no issues with this test version. I also let the app run for 5 minutes
          • #35
            will let it run for 15-25 mins now as I need to go to the store.
            • #36
              Thanks. If you have no further problems, I'll be ready for another release.
              tenholde
              • #37
                After 15 mins. I closed the app. And I have no issues at all.
                • #38
                  Version 3.5 of tenHsEvents is now available here. I would appreciate any feedback.
                  Changes:
                  Eliminated receiving Log events from HS, as there are bugs in HS with this.
                  Still display log, retrieving a fresh copy of recent entries periodically.
                  Open button for tenHsEvents Log now red if new entries exist.
                  Now coordinates with tenScripting to show HS Events and the HS Log
                  Minor additional bug fixes.
                  Thanks for everyone's patience.
                  tenholde
                  • #39
                    Upgraded to 3.5
                    1) No events were shown in the window (completely blank) on startup. Even though all devices/floor/Rooms were ticked in the filters, I had to select 'All' before I got entries being logged.
                    2) Loads of duplicate device name messages in the HS Log. They are not duplicates and have different addresses/reference numbers. For example I have a UPS plugin which runs on several PC's.
                    Jon
                    • #40
                      Originally posted by jon00 View Post
                      Upgraded to 3.5
                      Thanks, I'll look at the startup issue.
                      I'm surprised at how many people have duplicate fully-qualified device names. So, I assume that the program is now treating all devices with the same fully-qualified names the same and filtering them together? Is this acceptable, or do I need to differentiate between/among them?
                      tenholde
                      • #41
                        I have not looked at this in any detail but your log messages seem to indicate that they have been ignored:
                        Feb-17 16:37:49 tenHsEvents Duplicate Device Name Ignored: Utility Jon00 Eaton UPS UPS Information
                        Feb-17 16:37:49 tenHsEvents Duplicate Device Name Ignored: Utility Jon00 Eaton UPS Communications
                        Feb-17 16:37:49 tenHsEvents Duplicate Device Name Ignored: Utility Jon00 Eaton UPS Output Voltage
                        Feb-17 16:37:49 tenHsEvents Duplicate Device Name Ignored: Utility Jon00 Eaton UPS Est Energy Consumption
                        Feb-17 16:37:49 tenHsEvents Duplicate Device Name Ignored: Utility Jon00 Eaton UPS Output Load Watts
                        Feb-17 16:37:49 tenHsEvents Duplicate Device Name Ignored: Utility Jon00 Eaton UPS Output Load %
                        Feb-17 16:37:49 tenHsEvents Duplicate Device Name Ignored: Utility Jon00 Eaton UPS Est Run time
                        Feb-17 16:37:49 tenHsEvents Duplicate Device Name Ignored: Utility Jon00 Eaton UPS Battery Capacity
                        Feb-17 16:37:49 tenHsEvents Duplicate Device Name Ignored: Utility Jon00 Eaton UPS Status
                        Feb-17 16:37:49 tenHsEvents Duplicate Device Name Ignored: Utility Jon00 Eaton UPS Root
                        Feb-17 16:37:49 tenHsEvents Duplicate Device Name Ignored: Utility Jon00 Eaton UPS Event Log
                        Jon
                        • #42
                          tenHsEvents will keep the first device with the same fully-qualified name and drop any additional ones, giving the message. tenHsEvents relies solely (right now, at least) on the full name for processing, so if you filter on a location or device that affects the device it kept, it should filter on all devices with the same name. If not filtered, then any of the devices with that name should appear in the list as their values change. The drawback is that you cannot separately filter among devices with the same fully-qualified name. Is this acceptable, or if not, I will retool this approach.
                          Still trying to find issue with startup. Have you saved any triggers yet? Could you post your config file: users/xxxx/appdata/local/tenware/tenhseventsxxxxxx/version/user.config
                          tenholde
                          • #43
                            No, I just loaded your latest version before I had my evening meal and noticed the issues posted. I have not had time to 'play'.
                            I'm fine with the filtering as is. I suppose one way would be to start/append the device reference number to the full device name?
                            Here is the config file:
                            <?xml version="1.0" encoding="utf-8"?>
                            <configuration>
                            <configSections>
                            <sectionGroup name="userSettings" type="System.Configuration.UserSettingsGroup, System, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" >
                            <section name="tenHsEvents.My.MySettings" type="System.Configuration.ClientSettingsSection, System, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" allowExeDefinition="MachineToLocalUser" requirePermission="false" />
                            </sectionGroup>
                            </configSections>
                            <userSettings>
                            <tenHsEvents.My.MySettings>
                            <setting name="HsComputer" serializeAs="String">
                            <value>192.168.1.XX</value>
                            </setting>
                            <setting name="UpgradeSettings" serializeAs="String">
                            <value>False</value>
                            </setting>
                            </tenHsEvents.My.MySettings>
                            </userSettings>
                            </configuration>
                            Jon
