TED Pro Script variables
  • Pnord
    Return to TED
    First of all, thanks Sparkman & Mr Happy for your help, it did the trick !
    I've returned to this TED project fun with all new ideas !
    AND new problems.
    I went to the TED support forum page & asked:
    I have a VB script running in Homeseer reading the TED XML values.
    For the MTU:
    TEDAddress = TEDURL & "/history/export.xml?D=0&M=0&C=1&T=3"
    TEDXML.Load(TEDAddress)
    TEDNode = TEDXml.SelectSingleNode("HISTORY/HOUR/POWER").InnerText
    and similarly for the Spyders i = 1 to 16:
    TEDAddress = TedURL & "/history/export.xml?D=1&M=" & i & "&C=1&T=2"
    The above DOES work great !!!! For HOUR data. Now I want to get minute data.
    I should (in my mind) be able to adjust the T= parameter down one to T=2(MTU) or T=1 for spyder, change the "HOUR" to "MINUTE"
    in the XML read and have that work also, NOPE!. I've tried several combinations and the above HOUR script is the only
    combo that I can make work. The XML (viewed in a browser with with different D,M,T & C values set) works for any value I enter & the tree structure appears the same for any T= except the <HOUR>tag changes & becomes <SECOND> or <MINUTE> etc.
    Whats the trick?
    The reply I got from them was:
    I would agree that what you are doing should produce the results you expect. I just wonder if the TEDXML.Load() function is doing something to the parameters passed to it. I don't think that this is a TED problem, and you may want to repost your question in a Homeseer support forum.
    So, here i am. once again missing a piece.
    Help,
    Paul
    P.S. I've got a TED PRO with 16 Spyder CT's
    D = Device type ( 0 for Main MTU, 1 for Spyder units)
    M = Device number
    T = Time 1= second, 2 = minute etc. (offset by 1 for for D = 1 or 2)
    C = count, number of records returned
  • Pnord
    Works !!!
    I'm now recording all 16 values to hs.writelog
    All three of your suggestions , Convert.ToString(i), Cstr(i) & Spaces between everything M=" & i & "&C=1 worked
    Thanks for helping out old people.
    Paul
    Stay tuned to see how badly i can mess up the "adodb.connection"
  • mrhappy
    It should work looking on the face of it, just try separating by a space (M=" & i & "&C=) but it should still work regardless, what actually do you get when it is run? It could point to something else being wrong. Also try
    for i as byte = 1 to 16
  • sparkman
    Originally posted by Pnord View Post
    Moving to HS3 is challenging !
    I must be the only guy still using TED. I have the TED Pro? TED 6000? version with 16 spyder sensors.
    In HS2:
    for i = 1 to 16
    xmlfile = "http://xyz.com/history/export.xml?T=2&D=1&M="&i&"&C=1"
    XMLDoc.Load(xmlfile)
    ....select node stuff...here
    next
    This loaded each of my 16 spyder values (T=2 for hours, D=1 for Spyder Devices, M= Which Spyder , C=Number of records to return.
    I then assigned the values to Devices & recorded them to a database. (Challenges for another day, today writing to the log will suffice)
    In HS3 this line is giving me fits.
    The problem is in the "i" variable, if I manually insert an integer (ie 3) in the M= spot, I do get the spyder#3 watt value returned 16 times (3 is my water heater)
    I have tried every combination of ("&i&") I can think of.
    How do you insert "i" into the path?
    Paul
    BTW I have bought some of the Aeon Z-wave devices & am finding them to be more accurate. I am hoping to compare the data from both & maybe fine tune my TED measurements.
    have you tried
    VBScript:
    & CStr(i) &
    or
    VB.NET
    & Convert.ToString(i) &
    Cheers
    Al
  • Pnord
    started a topic TED Pro Script variables
    In HS2:
    for i = 1 to 16
    next
    Paul
