When I used this code in HS2 (with a device code) all worked fine, now trying to get it to go in HS3 in and .asp file it chokes.
Script error: Invalid procedure call or argument: 'hs.SetDeviceString'
hs.SetDeviceString "132",text
The doc says to use parens and when I tried that I still got errors.
In the same code stub, I try to use SetDeviceValue, the HS3 doc directs the use of the device's code like "A10, etc. What happened to using the reference number or is this a type?
hs.speak won't speak unless I enter "*:*" following the speech text. The doc makes no mention of needing it. Am I doing something wrong or not reading eh doc right?
