Export Timer Value to CSV every 24 hours
  • Export Timer Value to CSV every 24 hours
    I have never worked with scripts other than modifying my startup and shutdown scripts in very basic ways. I love HS3 but rarely get time to do more than the basic stuff.
    I am wondering if someone could point me in the right direction for writing a script(or using a plug-in) that could export the value of a timer to a CSV file at the end of each day. I have timer active whenever my HVAC is NOT idle. So, I'd like to get a daily value added to a .CSV so I can keep track of the run time.
    I appreciate any help you can give. Thanks
    Ryan
    Current Date/Time: 1/8/2017 10:45:21 PM
    HomeSeer Version: HS3 Standard Edition 3.0.0.297
    Operating System: Microsoft Windows 7 Home Premium - Work Station
    System Uptime: 1 Day 22 Hours 56 Minutes 8 Seconds
    IP Address: 192.168.1.149
    Number of Devices: 37
    Number of Events: 10
    Available Threads: 200
    Enabled Plug-Ins
    3.0.0.75: HSTouch Server
    3.0.1.66: Z-Wave
    Last edited by ryanbmsu; January 8th, 2017, 10:46 PM. Reason: Added system profile.
    The script in this thread below is probably a good starting point. What data do you want to go into the CSV? Just the date and the value? Also take a look at this: https://board.homeseer.com/showthread.php?t=171875.
    Cheers
    Al
    HS 3.0.0.548: 1965 Devices 1146 Events
    Z-Wave 3.0.1.262: 122 Nodes on one Z-Net
      Great. Thanks. I'll take a look at the script in that thread. After doing more searching I stumbled on the Jon00 Database Charting tool but I was not able to find it on his site. Not sure if I just missed it or if it had been removed.
      As you mentioned, I was just looking to export a timestamp and current timer value.
      Thanks again!
        Thanks again!
        You're welcome. You can access his site by just clicking on his signature banner in any of his posts.
        Cheers
        Al
          Cheers
          Al
          Yeah, I just couldn't locate the utility once in the site. I'll look around again. Lots of good stuff in there.
            Here's what I use to write HVAC times to a file each night:
            PHP Code:
            Sub Main(Parms as Object)
            Dim sw as System.IO.StreamWriter
            Try
            sw = New System.IO.StreamWriter("/usr/local/HomeSeer/Data/HVACTimers.txt",True)
            sw.WriteLine("BR HVAC" "," Now().ToString("MM-dd-yyyy") & "," hs.TimerValue("BR HVAC Runtime"))
            sw.WriteLine("LR HVAC" "," Now().ToString("MM-dd-yyyy") & "," hs.TimerValue("LR HVAC Runtime"))
            sw.Flush()
                    Catch
            ex as Exception
                         hs
            .writeLog("WriteHVACTimersToFile",ex.message)
                    Finally
                         If(
            Not sw Is Nothingthen sw.Close()
            End Try
            End Sub
