Hs.geturl doesnt work anymore
  • Hs.geturl doesnt work anymore
    Hi all ,
    After so e busy months i get an Error on my script.
    IT always worked. I thought the url was changed but is not changed..
    So i did an immediate command for let the webpage return the info in my log of homeseer, but nothing happens.. Not even an Error.
    &hs.geturl(thewebsiteadress.com","/resource/m9d-ebf2.json?sign=123",false,80)
    Did there change something ?
    Im still on .293
    Regards.
    Preferred -> Jon's Plugins, Pushover, Phlocation, Easy-trigger,
    HS3Pro 3.0.0.531 on windows 7 ultimate X64 on hp quadcore laptop 8 GB.
    What error do you get? If you did not update your HS install, then it's likely another issue. You do have a syntax issue in the command you posted (missing quote symbol).
    Cheers
    Al
    HS 3.0.0.548: 1976 Devices 1156 Events
    Z-Wave 3.0.1.262: 123 Nodes on one Z-Net
      Hi Al ,
      I still dont know what the problem was , but after a few clicks on the event iT works again, maybe a problem with my System...or connection
      The weird thing was i did not get any errors
      Gonna update homeseer Soon then...
