I have this script to determine minimum and maximum temperatures for the day. So far its been working fine, but now the temperatures dropped below 0 I have an issue. Going below 0, the minimum shows correctly, but when its going up again the lowest minimum goes up (and obviously it shouldn't). So as an example, the lowest temperature on my weather_temp was -2.5 degrees, and it showed that as minimum. Then the temperature did go up to -1.9 degrees, and the minimum value changed from -2.5 to -1.9 which should not happen.
This is the script I am using:
Sub Main(ByVal parms as Object) Dim out_temp = hs.devicevalueEx(14) Dim min_out = hs.devicevalueEx(768) Dim max_out = hs.devicevalueEx(767) Dim weather_temp = hs.devicevalueEx(19) Dim min_weather = hs.devicevalueEx(769) Dim max_weather = hs.devicevalueEx(770) Dim garage_temp = hs.devicevalueEx(15) Dim min_garage = hs.devicevalueEx(771) Dim max_garage = hs.devicevalueEx(772) If out_temp < min_out hs.setdevicevaluebyref(768, out_temp, true) hs.setdevicestring(768, out_temp, true) End If If out_temp > max_out hs.setdevicevaluebyref(767, out_temp, true) hs.setdevicestring(767, out_temp, true) End If If weather_temp < min_out hs.setdevicevaluebyref(769, weather_temp, true) hs.setdevicestring(769, weather_temp, true) End If If weather_temp > max_out hs.setdevicevaluebyref(770, weather_temp, true) hs.setdevicestring(770, weather_temp, true) End If If garage_temp < min_garage hs.setdevicevaluebyref(771, garage_temp, true) hs.setdevicestring(771, garage_temp, true) End If If garage_temp > max_garage hs.setdevicevaluebyref(772, garage_temp, true) hs.setdevicestring(772, garage_temp, true) End If End Sub
