catching GetURLImage errors
  • catching GetURLImage errors
    The documentation says
    Description: This is the contents of the requested web page image. If an error occurs, the text "ERROR:" will be returned followed by a reason for the error .
    Dim Snapshot1 As Object = hs.GetURLImage("http://" & CamUser & ":" & CamPassword & "@" & CamIP, CamPath, False, 80, Snapshot)
    But how do I write this error in the log file? The Snapshot1 variable is an object not a string.
    You could check if it returned a string:
    If Typeof Snapshot1 Is String Then hs.writelog("Camera Grab",Snapshot1)
    HS 3.0.0.532: 1963 Devices 1141 Events
    Z-Wave 3.0.1.261: 122 Nodes on one Z-Net
      Thanks for the tip it worked.
      I tried it this way
       If Snapshot1.GetType Is GetType(String) Then
      But that didn't work out (probably because I didn't understand the syntax). But your suggestion is a lot easier to understand.
        I tried it this way
        You're welcome! Glad it worked.
        Cheers
        Al
