Script doesn't work in HS but works in ten scripting
  • Script doesn't work in HS but works in ten scripting
    This is part of the script that I created in tentscripting
    Sub Main(parm As Object)
    	Dim CamUser As String = "user"
    	Dim CamPassword As String = "password"
    	Dim CamIP As String = "IP"
    	Dim CamPath As String = "/Streaming/Channels/1/picture/"
    	Dim Snapshot1 As String = "html/images/camera/1.jpg"
    	hs.GetURLImage("http://" & CamUser & ":" & CamPassword & "@" & CamIP, CamPath, False, 80, Snapshot1)
    End Sub
    It run in ten scripting without any errors. But when I compile in in HS I get this error
    Compiling script /etc/HomeSeer/scripts/test.cs: {interactive}(11,17): error CS1525: Unexpected symbol `Object', expecting `)', `,', `[', `]', or `=' {interactive}(13,8): error CS1525: Unexpected symbol `Dim', expecting `)', `,', `[', `]', or `=' {interactive}(30,37): error CS1519: Unexpected symbol `end-of-file' in class, struct, or interface member declaration {interactive}(30,37): error CS8025: Parsing error {interactive}(2,1): warning CS0105: The using directive for `System' appeared previously in this namespace {interactive}(3,1): warning CS0105: The using directive for `System.Linq' appeared previously in this namespace {interactive}(4,1): warning CS0105: The using directive for `Scheduler' appeared previously in this namespace {interactive}(5,1): warning CS0105: The using directive for `HomeSeerAPI' appeared previously in this namespace
    I have no idea how to trouble shoot this nor do I know what the error message means.
    I'm running HS on debian with mono. Is this the issue?
    Try naming it Test.vb rather than Test.cs. The script you posted is written in VB.NET
    Jon
      Wow I feel like such a dumb ...
      I can't believe I didn't paste it in the right script AND didn't see it.
      Thank you that did solved it.
