replace not working
  • replace not working
    I am trying to eliminate the word 'Reminder' from the body of a sms message before sending it to a TTS command. But is still speaking the full message
    Sub Main(parm as object)
     Dim reminder as String
     reminder = "$$DSR:331:"
     reminder = reminder.Replace("Reminder","")
     hs.speak(reminder,True, "$SONOS$KitchenTTS$")
    End Sub
    The sms body (in "$$DSR:331:") is 'Reminder this is a test message'
    and I want the result to be a TTS with 'this is a test message'
    Replacement variables do not work inside scripts. So reminder = "$$DSR:331:" returns exactly "$$DSR:331:". You need to use scripting commands to retrieve what you need.
    Cheers
    Al
    PS Looks like you are trying to get the status from a device. The scripting command for that is hs.CAPIGetStatus. The HS3 help file has a good example on how to use it.
      Cheers
      Al
      Sorry my knowledge of scripting is very limited. I am using below in another script, and that WORKS FINE
       Try
      energy_name = ""
      energystr = ""
       for each devt as string in array_energy
                         watts = hs.DeviceValueByNameEx(devt)
               If watts > 0
                         energy_name = devt
                         energy_name = devt.Replace("Watts","")
      This is only a part of the script, which I tried to adapt. The "$$DSR:331:" is from the SMS plugin, which hold the sms message body.
        There's nothing wrong with the replace function. The issue is the replacement variable "$$DSR:331:" which won't get replaced with the status of device 331 within the script. As per my first post, you would have to use the hs.CAPIGetStatus command to retrieve the status of device 331.
        This should work:
        	Dim CS As Object
        	CS = hs.CAPIGetStatus(331)
        	reminder = CS.Status
        End Sub
          This should work:
              Dim CS As Object
          End Sub
          Ok now I understand what you meant. And its working. Thanks
