replace not working
  • mikee123
    There's nothing wrong with the replace function. The issue is the replacement variable "$$DSR:331:" which won't get replaced with the status of device 331 within the script. As per my first post, you would have to use the hs.CAPIGetStatus command to retrieve the status of device 331.
    This should work:
    Sub Main(parm as object)
        Dim reminder as String
        Dim CS As Object
        CS = hs.CAPIGetStatus(331)
        reminder = CS.Status
        reminder = reminder.Replace("Reminder","")
        hs.speak(reminder,True, "$SONOS$KitchenTTS$")
    End Sub
    Ok now I understand what you meant. And its working. Thanks
  • sparkman
    This should work:
    	Dim CS As Object
    End Sub
  • mikee123
    Replacement variables do not work inside scripts. So reminder = "$$DSR:331:" returns exactly "$$DSR:331:". You need to use scripting commands to retrieve what you need.
    Cheers
    Al
    PS Looks like you are trying to get the status from a device. The scripting command for that is hs.CAPIGetStatus. The HS3 help file has a good example on how to use it.
    Sorry my knowledge of scripting is very limited. I am using below in another script, and that WORKS FINE
     Try
    energy_name = ""
    energystr = ""
     for each devt as string in array_energy
                       watts = hs.DeviceValueByNameEx(devt)
             If watts > 0
                       energy_name = devt
                       energy_name = devt.Replace("Watts","")
    This is only a part of the script, which I tried to adapt. The "$$DSR:331:" is from the SMS plugin, which hold the sms message body.
  • sparkman
    Cheers
    Al
  • mikee123
    started a topic replace not working
    replace not working
    I am trying to eliminate the word 'Reminder' from the body of a sms message before sending it to a TTS command. But is still speaking the full message
    End Sub
    The sms body (in "$$DSR:331:") is 'Reminder this is a test message'
    and I want the result to be a TTS with 'this is a test message'
