Anyone know what is wrong with this scrpt.
    Anyone spot what is wring with this script?
    Sub Main
    dim A
    Dim  B
    dim C
    A="Landy has moved to $$DSR:1083:"
    C = Len(A)
    B = (left(A,C-31))
    hs.speak B
     End Sub
    thanks
    HomeSeer 3 V 3.0.0.318 with ALEXA (AKA Amazon Echo)
    BL Radar V2.0.217; BLRF V2.0.85.0; HS Touch V3.0.0.1034 X10 V3.0.0.42; PHLocation V3.0.0.38; Zwave V3.0.1.110; X10 V3.0.0.42
    BLBackup V2.0.39;ImperiHome3.0.0.20 All on Windows XP Pro
    You cannot use replacement variables directly in scripts.
    This should work:
    PHP Code:
        Sub Main()
    Dim A
            Dim B
            Dim C
            A
    "Landy has moved to " hs.ReplaceVariables("$$DSR:1083:")
    Len(A)
    = (Microsoft.VisualBasic.Left(A31))
    hs.speak(B)
    End Sub
    Jon
      This should work:
      PHP Code:
          Sub Main()
      Dim A
              Dim B
              Dim C
              A
      Len(A)
      hs.speak(B)
      End Sub
      Thanks Jon,
      another thing gone from HS2, unfortunately your suggestion errors,
      Running script, script run or compile error in file: C:/Program Files/HomeSeer HS3/scripts/Landy moved.txt424:Object required: 'Microsoft' in line 7 More info: Object required: 'Microsoft'
        Sorry I forgot to remove that bit as you are running this in VBScript:
        B = (Microsoft.VisualBasic.Left(A, C - 31))
        becomes
        B = (Left(A, C - 31))
        Jon
          Thanks Jon, works perfectly, lots of script editing to do now.
          Appreciate your help.
