Did something change in HomeSeerAPI.Enums.dvMISC?
    I just found out that something has changed..
    before it works normal.
    when i use this in my code while creating devices selected from a ini file:
    dvp.MISC_set(hs, Enums.dvMISC.AUTO_VOICE_COMMAND)
    dvp.MISC_Clear(hs, Enums.dvMISC.AUTO_VOICE_COMMAND)
    It says : 'AUTO_Speech_COMMAND' is not a member of 'HomeSeerAPI.Enums.dvMISC'.
    Anyone a idea to solve it ?
    regards
    Preferred -> Jon's Plugins, Pushover, Phlocation, Easy-trigger,
    HS3Pro 4.0.8.0 on windows 10 enterprise X64 on hp quadcore laptop 8 GB.
    I think you have an error in your code because the error is that it can't find AUTO_Speech_COMMAND but the correct is AUTO_VOICE_COMMAND (they might mean the same thing if you have used a translation program?).
      Thanks!
      I see what gone wrong.
      I used notepad++ and used the command to change voice to speech.
      Thats what happend.
      Thanks again
