Json Deserialize (what do i forget) ?
    Hi all,
    Solved at post reply.
    Thx
    I did write a script that let me grab some json data, but there is one thing i dont know why it won't want to work.
    When i enter "lat" it works but not "house_number"
    This is the json site
    {"place_id":"164848013","licence":"API  LocationIQ.org CC BY 4.0, Data  testers, ODbL 1.0","osm_type":"way","osm_id":"437411681","lat":"17.42122785","lon":"78.4006673","display_name":"128, Road No 15, Prashasan Nagar, Hyderabad, Telangana, 500033, India","address":{"house_number":"128","road":"Road No 15","suburb":"Prashasan Nagar","city":"Hyderabad","state_district":"Hyderabad","state":"Telangana","postcode":"500033","country":"India","country_code":"in"},"boundingbox":["17.421132","17.4213237","78.4005923","78.4007423"]}
    This is my script :
    Imports Newtonsoft.Json
    		Imports Newtonsoft.Json.Linq
    		Sub Main (params as Object)
    	Try
    		Dim DataStr As String = hs.GetURL("http://test.org","/v1/reverse.php?format=json&key=mykey&lat=17.421223&lon=78.400674",true,80)
            Dim obj As New Object
    		Dim JSON As String = DataStr
    		dim json2 as string
    		JSON2 = JSON.replace("""","")
    		JSON2 = JSON.replace("","")
    		Dim SplitStr() As String = JSON.Split(",")
            Dim CurrentString As String
            Dim DPosition As Integer
            Dim StringToWorkWith As String
    		obj = JsonConvert.DeserializeObject(json2)
    		hs.WriteLog("Value of device", obj.item("lat").Tostring)
        Catch ex As Exception
            hs.writelog("JSON", "Exception: " & ex.message)
    	End Try
    		end sub
    If i use this hs.WriteLog("Value of device", obj.item("lat").Tostring) it writes out the latitude perfectly.
    but when i wat to use hs.WriteLog("Value of device", obj.item("house_number").Tostring) it writes an error in homeseer :
    JSON	Exception: Object reference not set to an instance of an object.
    Did i forget something ?
    regards
    Preferred -> Jon's Plugins, Pushover, Phlocation, Easy-trigger,
    HS3Pro 4.0.8.0 on windows 10 enterprise X64 on hp quadcore laptop 8 GB.
    Yes, you did forget something.
    This is how JSON looks when you format it for human reading
         "place_id": 164848013,
         "licence": "API  LocationIQ.org CC BY 4.0, Data  testers, ODbL 1.0",
         "osm_type": "way",
         "osm_id": 437411681,
         "lat": 17.42122785,
         "lon": 78.4006673,
         "display_name": "128, Road No 15, Prashasan Nagar, Hyderabad, Telangana, 500033, India",
         "address": {
             "house_number": 128,
             "road": "Road No 15",
             "suburb": "Prashasan Nagar",
             "city": "Hyderabad",
             "state_district": "Hyderabad",
             "state": "Telangana",
             "postcode": 500033,
             "country": "India",
             "country_code": "in"
         "boundingbox": [
            17.421132,
            17.4213237,
            78.4005923,
            78.4007423
    As you can see "lat" is field in the top level of this JSON object. "house_number" is not. You first have to fetch "address", and then with its reference you cab fetch "house_number". So something like, obj.item("address").item("house_number").ToString
      Solved
      Thanks for the help!!,
      I did to this hs.WriteLog("Value of device", obj.item("address")("house_number").Tostring) and it works
           "osm_type": "way",
           "lat": 17.42122785,
           "lon": 78.4006673,
           "address": {
               "postcode": 500033,
               "country": "India",
           "boundingbox": [
              17.421132,
              17.4213237,
              78.4005923,
              78.4007423
        How does it work with this ?
        I did fetch rows first,but when i want to fetch distance, i get an error.
        i also used :
        JSON = JSON.replace("[","")
        JSON = JSON.replace("]","")
        to remove the ]
           "destination_addresses" : [ "test, 34343434 nz test, country" ],
           "origin_addresses" : [ "test 14-16, 333333 nz test,country" ],
           "rows" : [
                 "elements" : [
                       "distance" : {
                          "text" : "1 m",
                          "value" : 0
                       "duration" : {
                          "text" : "1 min.",
                          "value" : 0
                       "status" : "OK"
           "status" : "OK"
        [CODE]
          [] in JSON denote arrays. To access element of an array you either have to loop through them (for loop) or provide array element index (starts from 0). Since I'm not familiar with vb.net syntax, this is the best I can do.
          For example, to access text field in second duration element (1 min.) you would use something like
          obj.item("rows")[0].("elements")[1].("duration").("text").ToString
            I have this Google distance matrix api perfect working in php with 3 different original and 3 destination addresses in one call, but I'm very interested in the vb.NET version
              Thanks for the reply ,
              I did try it but it didnt work
              I solved it now by retrieving everything to .item and it works
                Solved//
