First script on Linux
    Try:
    Sub Main(ByVal parm as Object)
    hs.writeLog("msg","Logged a message")
    End Sub
    68 Z-Wave Nodes, 175 Events, 359 Devices
      I believe you cannot use vbscript but must use vb.net??
      Make sure file suffix is .vb
      tenholde
      tenholde
        Progress! Thanks!
        Looks like i can't access the open comport method. How do i do that? Is that even a vb.net function? The scripting guide lists it: https://homeseer.com/support/homesee...lp/default.htm
        I am working towards a script that will receive data from a serial connected arduino, and eventually send data back to it.
        For now i have
        IMPORTS System.IO
        IMPORTS System.Net
        err = OpenComPort(1, "9600,N,8,1", 1, "comdatareceived.vb", "callback")
        hs.writeLog("msg", err)
        End Sub
        So that should open a com port (i need to figure out the port number, for now i put 1 in there till i get syntax correct), and call function callback in script comdatareceived.vb when data arrives.
        I get these errors:
        Compiling script /usr/local/HomeSeer/scripts/gettemps.vb: 'OpenComPort' is not declared. It may be inaccessible due to its protection level.
        Compiling script /usr/local/HomeSeer/scripts/gettemps.vb: The import 'System.Core' could not be found.
          In Linux, a COM port is not a number, but rather a device. You'll have to use something along the lines of: /dev/ttyUSB0 or wherever you have your serial connection.
          You'd probably be better off using the Arduino plugin for HS.
            Problem with the arduino plugin is it only supports ethernet on linux. That is an option but i had problems with it remaining stable.
            If the port is a string then i assume i cant do the opencomport, since it requires an integer?
            Thanks for the continued advice, much appreciated!
