Current date to device string
  • Current date to device string
    I would like to get the current date into a device string. The HS replacement variable $date has the info, but I am not sure how to get into device.
    &hs.setdevicesting(891,"Today is $date"),true - throws an error
    Larry
    try setdevicestring not setdevicesting
    Edit:
    Notice your parentheses arent right
    hs.setdevicesting(891,"Today is $date",true)
    But this doesnt seem to put the replacement variable in the string.
      thanks for catching my typos. It does not look like I can set a device to from a replacement variable.
      Running script(1) &hs.setdevicestring(891,$date),true, init error: Invalid character
      Larry
        Yeah I think you're right. You could use :
        hs.setdevicesting(891,"Today is " & now() ,true) but you probably wouldn't want that format.
        Looks like you're going to have to use a script to get it to work.
          You can use:
          hs.setdevicestring(891,"Today is " & hs.replacevariables("$date"),true)
          Jon
            It seems unnecessary to do a script for such a thing, but did it anyway:
            d=Now()
            d2=Format(d,"dddd, MMMM-d-yyyy")
            hs.writelog ("date info",d2)
            hs.setdevicestring(891,d2,true)
            Thanks Jon for your input.
            Larry
              I use script, but one liner:
              &nhs.SetDeviceStringByName("Time", now.ToString("HH:mm"), True) &
              hs.SetDeviceStringByName("Date", now.ToString("ddd. MMM  dd"), True)
