HS2 - HS3
    HS2 - HS3
    Hi I have a simple script that worked fine for years in HS2 I have juat changed to HS3 and ZWAVE I am wondering what changes I need to make to the script.
    All it does is check the value of a virtual device if it isn't 5 it sets to 5 and then turns on 2 lights via x10. I believe hs.ExecX10 still works and I am using the Z wave device as the address??
    Sub Main
    dim curr_timer_value
    curr_timer_value = hs.DeviceValue("T1")
    IF curr_timer_value = 0 Then
       hs.SetDeviceValue "T1",5
       hs.ExecX10 "Q111","on"
       hs.ExecX10 "Q143","on"
    else
      Exit Sub
    End If
    End Sub
    I do not believe ExecX10 exists in HS3.
    Also, SetDeviceValue may change the value stored in the device, but will not effect a physical device dimming level.
    You need to convert to CAPI commands for Device Control.
    Check out this utility that displays info about each of your devices, including the available CAPI commands for each device. It will also generate the script code to execute any of these commands and place it on the clipboard so you can easily paste it into your script editor.
    http://tenholder.net/tenWare2/tenScriptAid/default.aspx
    View the videos.
    tenholde
    tenholde
      This looks like this could be done in HS3 with out a script as counters are part of HS3 and can be used as triggers.
      -Rupp
        The capability to issue an X10 command in a script does exist in HS3, but the structure and the syntax are completely different from HS2 because X10 is no longer the organizing structure of HS. It is just another plug-in.
        See this thread: https://forums.homeseer.com/showthread.php?t=178701
        HW: Stargate | NX8e | CAV6.6 | Squeezebox | PCS | WGL 800RF | RFXCOM | Vantage Pro | Green-Eye | X10: XTB-232, -IIR | Edgeport/8 | Way2Call | Ecobee3 | EtherRain | Ubiquiti
          Or, why not just use the following:
          hs.CAPIControlHandler(hs.CAPIGetSingleControl(194,True,"On", False,False))
          to turn on the X10 device with a DevRef of 194
          tenholde
          tenholde
            basic script
            Hi Thanks for all your advice and looking into various solutions
            I am trying to get a simple script to work
            Sub Main
                hs.SetDeviceValueByRef(727, 60.54, True)
            End Sub
            When I try to run it I get
            VB.Net script exception(0), re-starting: Object reference not set to an instance of an object.
            as you can see from the attachment I have a virtual device with an address of 727
            I can't figure out what I am doing wrong..
            thanks
              I think that is a vb.net function. Try changing the script's first line to
              Sub Main(ByVal Parm As Object)
              then save it as a .vb file.
                worked
                That worked a treat!!
                thanks
