GetUrl Error
    GetUrl Error
    Hello,
    I have a script to retreive the day type (Blue, White, Red) from EDF site.
    This is work on Mozilla, Edge, Chrome:
    https://particulier.edf.fr/bin/edf_r...peAlerte=TEMPO
    The result is : {"JourJ":{"Tempo":"BLEU"},"JourJ1":{"Tempo":"ND"}}
    When i put this on my script:
    sub Main(parm as object)
    dim result as object
    Dim DataStr, DataStr1 as string
    DataStr1 = "/bin/edf_rc/servlets/ejptemponew?Date_a_remonter=2017-12-23&TypeAlerte=TEMPO"
    DataStr = hs.GetURL("https://particulier.edf.fr", DataStr1, True,80)
    hs.writelog ("test tempo ",DataStr)
    End Sub
    Hello,
    I find my problem
    I tested the command CURL in powershell
    the problem is the same.
    https://particulier.edf.fr/bin/edf_r...peAlerte=TEMPOhttps://particulier.edf.fr/bin/edf_r...tempodaysnew?T ...
    + CategoryInfo : InvalidOperation : (System.Net.HttpWebRequest:HttpWebRequest) [Invoke-WebRequest], WebEx
    ception
    + FullyQualifiedErrorId : WebCmdletWebResponseException,Microsoft.PowerShell.Commands. InvokeWebRequestCommand
    Now i set the protocol TLS 1.2 as default ( only for this session)
    The url command is OK
    PS C:\Users\Jean> [Net.ServicePointManager]::SecurityProtocol = [Net.SecurityProtocolType]::Tls12
    PS C:\Users\Jean> curl https://particulier.edf.fr/bin/edf_r...peAlerte=TEMPO
    StatusCode : 200
    StatusDescription : OK
    Content : {"PARAM_NB_J_BLEU":205,"PARAM_NB_J_BLANC":28,"PARAM_NB_J_ROU GE":18}
    RawContent : HTTP/1.1 200 OK
    X-Content-Type-Options: nosniff
    X-Frame-Options: SAMEORIGIN
    Vary: User-Agent
    X-XSS-Protection: 1; mode=block
    Strict-Transport-Security: max-age=15768000
    Content-Length: 67
    Conte...
    Forms : {}
    Headers : {[X-Content-Type-Options, nosniff], [X-Frame-Options, SAMEORIGIN], [Vary, User-Agent],
    [X-XSS-Protection, 1; mode=block]...}
    Images : {}
    InputFields : {}
    Links : {}
    ParsedHtml : mshtml.HTMLDocumentClass
    RawContentLength : 67
    Solution For Powershell BUT don't WORK with hs.GetUrl
    https://docs.microsoft.com/en-us/off...-online-server
    How to setup protocol Tls 1.2 working with hs.GetUrl?
    Help me, Thanks
    Jean-Francois.
      http://board.homeseer.com/showpost.p...50&postcount=1
          Hello, Pierre
          It's OK Now
          But we MUST Enable strong cryptography in .NET Framework 4.5 or higher
          AND
          Disable earlier versions of SSL and TLS in Windows Schannel
          By default, Entry doesn't exist in win10 registrery
          Use this link to add to registrery:
          https://www.fastvue.co/wp-content/up...LS_regfile.zip
          And follow the instructions in this link:
          Jean-Francois.
            Hi,
            Better solution:
            https://stackoverflow.com/questions/...ll-connections
            I put HS3 on another PC under WIN10 Fall Creator
            My script don't work again
            I apply the solution from stackoverflow, i reboot, and now, it's OK
            Jean-francois.
