Script TTS Pronounciation
    I have a script which speaks the outside temprature and under HS2 I used the following line to get it to say minus instread of dash for minus tempratures.
    x = Replace(x,"-","minus ")
    Under HS3 it does not work, any ideas how to get it to work under HS3
    HomeSeer 3 V 3.0.0.318 with ALEXA (AKA Amazon Echo)
    BL Radar V2.0.217; BLRF V2.0.85.0; HS Touch V3.0.0.1034 X10 V3.0.0.42; PHLocation V3.0.0.38; Zwave V3.0.1.110; X10 V3.0.0.42
    BLBackup V2.0.39;ImperiHome3.0.0.20 All on Windows XP Pro
    It looks like it should work.
    What is the text in X?
    What error messages do you get?
    HW: Stargate | NX8e | CAV6.6 | Squeezebox | PCS | WGL 800RF | RFXCOM | Vantage Pro | Green-Eye | X10: XTB-232, -IIR | Edgeport/8 | Way2Call | Ecobee3 | EtherRain | Ubiquiti
        Here is the main part of the script -
        sub main()
        	Dim a
        	Dim b
        	Dim c
        	Dim d
              Dim x
        hs.speak "Good "& TimeOfDay() & ".. The time is " & myTime() & "..It is" & WeekdayName(DatePart("w", Date)) & MonthName(DatePart("m", Date))& ",,the" &  myday() & "," & "and the current outside temperature is $$Dsr:408:.." & "," & "but it feels like $$Dsr:418: ..",TRUE,"Control:Livingroom"
        Dsr 408 and 418 are the temperature devices.
          I think you need to assign the string to be spoken to x first, then do the replacement, then do the speaking.
          I'd expect it to look something like:
          x = "Good "& TimeOfDay() & ".. The time is " & myTime() & "..It is" & WeekdayName(DatePart("w", Date)) & MonthName(DatePart("m", Date))& ",,the" &  myday() & "," & "and the current outside temperature is $$Dsr:408:.." & "," & "but it feels like $$Dsr:418: ..",TRUE,"Control:Livingroom"
          hs.speak x
            hs.speak x
            Thanks for the suggestion. No that does not work, still sway's "dash" rather than "minus""
              That's a puzzle. I think it's time for a simpler test.
              I'm thinking of a very short script, something like:
              x = "This is a - test. This is a -test. This is -5 test."
              hs.WriteLog "sub test", x
                That little script works perfectly. Found the problem when I changed the greeting script to write to log,
                	Good Evening.. The time is 9, O7..It isSundayJanuary,,the7th,and the current outside temperature is $$Dsr:408:..,but it feels like $$Dsr:418:
                x does not know what $$Dsr:* actually is
                  Originally posted by Gogs View Post
                  Found the problem when I changed the greeting script to write to log, x does not know what $$Dsr:* actually is
                  A step forward! I use writelog a lot for that very reason. Now you just have to find a way to translate the replacement variable before applying the replacement function.
                    Hoping someone will jump in here as I have not a clue how to do it under HS3
                      What if you substitute hs.DeviceString() for the replacement variable? Then
                      would become
                      & "and the current outside temperature is " & hs.DeviceString(408) & ","
                        would become
                        Thanks tried that, HS3 does not support hs.DeviceString or Value!
                          Two things
                          1. $$DSRevREF: is not the string value, it is the Device Status. $$DTRevREF: is the Device String See help.
                          2. The HS3 Device Class does support hs.DeviceString and hs.DeviceValue see help. There is not an equivalent (that I have found) to return the Device Status.
                          Randy Prade
                          Aurora, CO
                          Prades.net
                            Two things
                            Thanks, but $$DTR still will not reveal the value to x,
                            Jan-08 20:16:00
                            sub test Good Evening.. The time is 8,16..It isMondayJanuary,,the8th,and the current outside temperature is $$Dtr:408:..,but it feels like $$Dtr:418: ..
                              My installation of HS3 supports both. What have you tried that leads you to think that HS3 doesn't support hs.DeviceString()?
