Calculate occupation time
    I'm trying to calculate the time between the current time and the time that the device has changed for the last time.
    &hs.setdevicestring(259,TIME-NOW,true) doesn't work
    And is it possible to calculate the time in hours:min when the current time-the time that the device has changed for the last time < 24 hours and calculate the time in days when the current time-the time that the device has changed for the last time > 24 hours?
    I want to show show the occupation time in hours or days depending on < 24 hours and > 24 hours in HStouch.
    For example:
    01:30
    or
    2 days
    Have a look at the DateDiff function: Here
    http://www.midondesign.com
      Thanks Midon,
      But when i try to use the DateDiff a get a strange result:
      &hs.setdevicestring(259, DateDiff("h",now,time),true)
      result: -1034520
        What are the values of now and time?
        HW: Stargate | NX8e | CAV6.6 | Squeezebox | PCS | WGL 800RF | RFXCOM | Vantage Pro | Green-Eye | X10: XTB-232, -IIR | Edgeport/8 | Way2Call | Ecobee3 | EtherRain | Ubiquiti
          Uncle Michael,
          I think i've to make a second virtual device so that i can extract the time stamp from the device that has been changed from the current time.
          At this moment when the device status changes, the device string = current time-time stamp (which is also the same time as the current time) The result is always the same: -1034520
            I just tried this script:
                Sub Main(ByVal Params As Object)
                hs.setdevicestring(1407, DateDiff("n",hs.DeviceLastChangeRef(502),NOW),true)
                End Sub
            (My time since last change is less than 20 minutes ago, so I chose minutes rather than hours.) My device string reads '9', when the device changed nine minutes ago, '6' when it had been six minutes.
            I'm suspicious that the value of your 'time' is not in date format. If you use the HS function for device last change in your formula, it should give you the result you are looking for.
                  End Sub
              I will give it a try!
              Thank you for your input
              EDIT:
              Thank you Uncle Michael, that works great!
