Scripting with variables
    I made this short script to get the latest weather warning from the weather XML plugin.
    Sub Main(ByVal Params As Object)
    Dim AlrtTitle As String
    AlrtTitle = hs.GetVar("wxmlAlertTitle_1")
    hs.SetDeviceString( 1381, AlrtTitle, True)
    end sub
    How do set the device string to something else once the alert is over and the variable is no longer there?
    Tim
    FB Page - https://www.facebook.com/pages/Capt-Tim/209398425902188
    HSTouch Layouts - https://www.facebook.com/media/set/?...5902188&type=3
    To set the device string to something else, you need to repeat the hs.SetDeviceString function. If you want to remove the string and leave it blank set it to null:
    hs.SetDeviceString( 1381, "", True)
    (You can use an immediate script command if you want to do without creating another script.)
    HW: Stargate | NX8e | CAV6.6 | Squeezebox | PCS | WGL 800RF | RFXCOM | Vantage Pro | Green-Eye | X10: XTB-232, -IIR | Edgeport/8 | Way2Call | Ecobee3 | EtherRain | Ubiquiti
      Hey Tim... Long time no talk...
      You probably can use the following as well. Note "desiredvariable" is the name of the variables contents that you want to put into the device string.
      hs.SetDeviceStringByName("Kitchen Counter Lights", desiredvariable, True)
      If not, then let me know.
      Make sense?
        I think I didn't explain it right.
        When a weather alert becomes active, the Weather-XML plugin creates a variable for that alert. Once the alert has expired, that variable is no longer accessible. It just disappears from the list of variables for Weather-XML.
        So if there is an alert I can use it, if there is no alert I want to put "No Active Alert" in the device string.
        Tim
          Sill can't figure this out.
          How do I tell the script to either use the variable (when it's available) or to use "No active alerts" (when it's not available) ?
          Tim
            I did this by creating a virtual device and two events. I can then use the virtual device value to set or remove messages.
              Tim
              Try this:
                      hs.CreateVar("wxmlAlertTitle_1")
                      If AlrtTitle = "" Then
                          hs.SetDeviceString(1381, "No active alerts", True)
                      Else
                          hs.SetDeviceString(1381, AlrtTitle, True)
                      End If
                  End Sub
              Jon
                Thank you, Jon
                It works for now, will have to wait for a weather warning now.
                Tim
