Undocumented Scripting/Plugin functions
    I've started this thread to collate a list of scripting/plugin calls which are currently undocumented and may get lost if not recorded somewhere:
    Device Name from reference:
    hs.devicename(deviceRef As integer) as String
    Event Voice Command from reference (Introduced in version 3.0.0.407)
    hs.GetEventVoiceCommand(eventRef as integer) as String
    If you know any more, feel free to post here.
    Jon
    I can't add to this list, but really appreciate you starting it.
    Don
      +1
      67 Z-Wave Nodes, 111 Events, 422 Devices
      Z-Wave, UPB, WiFi
      Plugins: EasyTrigger, weatherXML, OMNI, Z-Wave, Tuya, Device History
        Check to see if an Application is running:
        hs.IsApplicationRunning(Application Name As String) As Boolean
        Example:
        Sub Main(ByVal Parm As Object)
            If Not hs.IsApplicationRunning("Notepad") Then
            hs.Speak("NotePad is not running")
        End if
        End sub
        Jon
          Added to the Device Class - Get/Set the Linked Device
          (Introduced in version 3.0.0.451)
          Public Property LinkedDevice(ByVal hs As IHSApplication) As Integer
          This returns or sets the Linked Device Reference for the device: It returns 0 if no devices are linked, else the reference number.
          Example:
              Dim RefNo As Integer = 123
              Dim dv As Scheduler.Classes.DeviceClass
              dv = hs.GetDeviceByRef(RefNo)
              hs.writelog("LinkedDeviceRef", dv.LinkedDevice(nothing))
          End Sub
          Jon
            Device Unknown status;
            hs.DeviceInvalidValue(xxxx) to get it
            hs.DeviceInvalidValue(xxxx)= false to set
            xxxx = ref
            Regards Bart
            Win7 64Bit on Intel NUCI7 with SSD
            HSPRO 3.
            Devices; 1370 Events; 691
            Jon00 Scripts, JowHue, HSTouch, Plugwise, Z-wave, Ultranetatmo, Ultracam, PHlocation, BLUSBUIRT, MeiHarmony, Buienradar, MEiUnifi Pushover 3P, Random, Nest HSPhone and Blueiris
            Visonic Powermax Alarm System (HS3) Interface: http://www.domoticaforum.eu/viewtopic.php?f=68&t=11129
              Example:
              End if
              Will have to test this on linux
                Syntax is lacking a just little bit for those not all that familiar with VB .net syntax:
                  End if
                End Sub
