hs.OpenComPortEx Error
    I get this error
    Running script Startup.vb :Exception has been thrown by the target of an invocation.
    Public member 'OpenComPortEx' on type 'hsapplication' not found.
    When Startup.vb runs with this
    Dim e = hs.OpenComPortEx(15,"9600,n,8,1",0,"RFIDlogging.vb","Main")
               If e <> "" then
                   hs.WriteLog("Error", "Failed connecting to rfID receiver")
               Else
                   hs.WriteLog("COM 15", "Successful connection")
               End If
    Is OpenComPortEx still supported or do I have something wrong?
    OpenComPortEx has gone in favour of OpenComPort and OpenComPortTerm, if you need a termination character then use the latter. Sadly OpenComPortEx is still in the documentation which causes a bit of confusion.
