Hello
I'm trying to run an event on startup , basic event to send a pushover notification telling me that HS3 have restarted in case of computer reboot or power outage
I have zero scripting experience but users here are really helpful so this is what the end of startup script looks like
everything worked fine before adding the " hs.TriggerEvent ("Startup") " , after I add it I get an error in HS3 log
any idea how to make this work properly ?
Rami
' You may add your own commands to this script.
' See the scripting section of the HomeSeer help system for more information.
' You may access help by going to your HomeSeer website and clicking the HELP button,
' or by pointing your browser to the /help page of your HomeSeer system.
hs.Launch (hs.GetAppPath & "\Jon00PerfMonHS3.exe","","",0)
hs.RegisterStatusChangeCB("L2DB-influxdb.vb","Main")
End Sub
End Sub
Jun-07 1:08:07 PM Error Compiling script C:\Program Files (x86)\HomeSeer HS3\scripts\Startup.vb: 'If', 'ElseIf', 'Else', 'End If', 'Const', or 'Region' expected.
Jun-07 1:08:07 PM Error Compiling script C:\Program Files (x86)\HomeSeer HS3\scripts\Startup.vb: Namespace or type specified in the Imports 'System.Core' doesn't contain any public member or cannot be found. Make sure the namespace or the type is defined and contains at least one public member. Make sure the imported element name doesn't use any aliases.
Rami
