Event triggered manually, cannot re run for x minutes
  • #16
    Thats good. I'll try over the next few days. I guess .455 is a beta ?
    • #17
      Yes .455 is a beta. It is at https://homeseer.com/updates3/SetupHS3_3_0_0_455.msi
      I can confirm it is fixed. I just enabled my test events again
      The script:
      Sub Main(Parm As Object)
          hs.WriteLog("Trace", "Event Test 1 ran")
          hs.triggerevent("Test 2")
      end sub
      And here are the log results
      Jul-09 12:04:48 PM Trace Event Test 1 ran
      Jul-09 12:03:48 PM Trace Event Test 1 ran
      Jul-09 12:02:48 PM Trace Event Test 1 ran
      Jul-09 12:02:48 PM Trace Test 2 Event Ran
      Jul-09 12:01:48 PM Trace Event Test 1 ran
      Jul-09 12:00:48 PM Trace Event Test 1 ran
      Jul-09 11:59:48 AM Trace Event Test 1 ran
      Jul-09 11:58:48 AM Trace Event Test 1 ran
      Jul-09 11:57:48 AM Trace Event Test 1 ran
      Jul-09 11:57:48 AM Trace Test 2 Event Ran
      Jul-09 11:56:48 AM Trace Event Test 1 ran
      Jul-09 11:55:48 AM Trace Event Test 1 ran
      Jul-09 11:54:48 AM Trace Event Test 1 ran
      Jul-09 11:53:48 AM Trace Event Test 1 ran
      Jul-09 11:52:48 AM Trace Event Test 1 ran
      Jul-09 11:52:48 AM Trace Test 2 Event Ran
      Jul-09 11:51:48 AM Trace Event Test 1 ran
      Jul-09 11:50:48 AM Trace Event Test 1 ran
      Jul-09 11:49:48 AM Trace Event Test 1 ran
      Jul-09 11:48:48 AM Trace Event Test 1 ran
      Jul-09 11:47:48 AM Trace Event Test 1 ran
      Jul-09 11:47:48 AM Trace Test 2 Event Ran
      Jul-09 11:46:48 AM Trace Event Test 1 ran
      Jul-09 11:45:48 AM Trace Event Test 1 ran
      Jul-09 11:44:48 AM Trace Event Test 1 ran
      Jul-09 11:43:48 AM Trace Event Test 1 ran
      Jul-09 11:42:48 AM Trace Event Test 1 ran
      As you can see, the 5 minute "Cannot Re-Run For:" is now respected when called by a script. It was already respected when called from another Event or launched from the Event Management page.
      Thank you Rich
      Randy Prade
      Aurora, CO
      Prades.net
      • #18
        When there is a newer release version, will I get the prompt to update still (as I am on a beta) ?
        • #19
          Yes, as long as "Check for HS3 Update at Startup" is enabled in setup. It just looks for a higher version than what is installed at startup, regardless of whether you are running a beta or release version.
          Randy Prade
          Aurora, CO
          Prades.net
          • #20
            I am no ready to put out an official Beta, but if you need this fix, the Windows installer for 455 is here:
            http://homeseer.com/updates3/SetupHS3_3_0_0_455.msi
